1978 - 1996 Big Bronco
93 Bronco Cam question
Old Oct 24, 2016 | 06:41 AM
Bad1993's Avatar
Bad1993
I was wondering if a cam for a 351w can be put in the 302w in a Ford truck engine I am trying to make my bronco wake up a bit and I heard of a 351w cam going into a 302w will wake that engine up like crazy..... So who has done this and is there any issues to watch for?
Old Oct 24, 2016 | 11:53 AM
Kemicalburns's Avatar
Kemicalburns
cam changes can be helpful. the thing is you need to have other items done first to acquire those gains.
are you still running stock exhaust manifolds? stock exhaust. what else is built on the truck? tire size, gears and what goals are you looking for.
Old Oct 24, 2016 | 02:25 PM
Beechkid's Avatar
Beechkid
yes, IIRR with a change to the firing order, but, there is really no reason to do that when Isky, crower, etc have excellent grinds for the 302 that will provide all those gains and more...........
Old Oct 24, 2016 | 06:52 PM
Conanski's Avatar
Conanski
If the motor in your '93 is original it has a roller cam in it while most 5.8 motors of this vintage and older had flat tappet cams, so swapping one of those in would be a step backwords. But the stock cam in your motor is very small so you would benefit from an upgrade but I wouldn't suggest installing another stock cam because they're all really tame.. buy something aftermarket like the Comp 35-512-8
Old Oct 27, 2016 | 01:14 PM
Bad1993's Avatar
Bad1993
ok tranny is built to the point it is unbreakable I ran it dry on the highway once old owner did nothing but build the tranny it has 33" tires and JBA shorty headers all I Wana achieve is when I stomp it I Wana break the tires loose from a dead stop axle has 355 gears open rear end planning on putting in a posi trac kit where u just replace the spyder gears
Old Oct 27, 2016 | 01:16 PM
Bad1993's Avatar
Bad1993
so if I ordered that cam and brought it to a shop what else would need to be replaced/ upgraded?
Old Oct 27, 2016 | 02:27 PM
Kemicalburns
i would upgrade the gears first to 4.10s
the cam will require the front of motor coming apart so new water pump, timing chain and new Tstat.
Old Oct 27, 2016 | 06:01 PM
gatorfor88's Avatar
gatorfor88
Be careful what you wish for. You start breaking 33's loose and that aint all you'll be breaking.
Old Nov 6, 2016 | 11:22 AM
Bad1993's Avatar
Bad1993
but it's 4x4 changing the gearing in the rear would require it to be done in the front also or the transfer case will fail
Old Nov 9, 2016 | 10:53 AM
Kemicalburns
thats correct Bad1993, must change the gears front and rear. sorry i wasnt specific on that.
Hardlanding
Jan 21, 2016 08:02 AM
atccracing
34
Feb 26, 2014 08:29 PM
4drf350
1966 - 1977 Early Broncos
Jul 1, 2010 08:56 AM
flareside_thunder
18
Oct 18, 2007 09:32 PM
Jason8705
Aug 5, 2007 02:00 AM
