Sponsored by: Real Truck
What is this?
Old Oct 23, 2016 | 05:34 PM
gabriell12123's Avatar
gabriell12123
What is this?
What are the connectors with the blue tips to the left of the fuse box, is this a power source i bought a PA system with a horn and what not and i want to see if this is a power source because the positive and negative cables on the PA sytem are only about a foot long.
Old Oct 23, 2016 | 05:36 PM
mattymax's Avatar
mattymax
Looks like two grounds. Did you buy the truck used ? It's most likely the old owner had soemthing grounded there and cut it before they sold it. Plow, lights ex. Some accessory
maft
Old Oct 23, 2016 | 05:41 PM
Canwan's Avatar
Canwan
That is an automatic resetting breaker. They were quite often used to power the power pin in the trailer plug. They were also frequently used to power an aftermarket brake controller.
Old Oct 23, 2016 | 05:53 PM
gabriell12123
Hmm okay. I was hoping I could run power from it. Thank you
Old Oct 23, 2016 | 05:55 PM
gabriell12123
maft
I did buy it used. Was hoping I could've made use of it. Thank you!
Old Oct 23, 2016 | 06:36 PM
montauk1's Avatar
montauk1
Use a 12V test light & see what you get.
John
Old Oct 23, 2016 | 06:42 PM
Canwan's Avatar
Canwan
It won't have power. The wires have been cut.
What you have is similar to these.
https://www.etrailer.com/dept-pg-Acc...t_Breaker.aspx
Put power to one side, and you will get power out the other side. It works like a fuse except when there is too much load (a short for example) it opens the circuit to remove power from the load. Then when it cools, it closes the circuit again. (resets)
ittybitty
Transit Connect
Nov 6, 2016 06:56 PM
bigcrunch
Sep 14, 2014 06:17 PM
JimGeorge0723
Electrical Systems/Wiring
Jul 14, 2014 09:36 AM
Moonhawk
Apr 20, 2011 06:55 PM
Flatlanded87
Oct 14, 2006 05:39 PM
