Uh Power Point? What?
Old Oct 14, 2006 | 12:22 AM
Flatlanded87's Avatar
Flatlanded87
Hi there, 87 f150 4x4, 5.0L.
I just recently discovered I have a dead short in my "power point" circut. It blows up anything u stick in there... First of all... What IS my "power point" and second, is there any typical reasons for this or should I just trace the wires and find the short.
I didn't realize my truck came with MS Office...
Thanks as always for any replies!
Old Oct 14, 2006 | 01:11 AM
lowdownndirty's Avatar
lowdownndirty
power point as in ,the the 12v power source for your favorite I pod, cell phone charger etc?...Ie cirgerate lighter with out the lighter part.
Old Oct 14, 2006 | 01:17 AM
Flatlanded87
I'm not sure what your talking about... The cigarette lighter is another circut with a 75amp fuse. This is a 30amp circut with no other explanation in my haynes manual then "Power Point".
Old Oct 14, 2006 | 02:59 AM
nighthawk285's Avatar
nighthawk285
are you talking about the places in your fuse box that already have power to them, but arent hooked to anything?
Old Oct 14, 2006 | 03:31 AM
todd31277's Avatar
todd31277
what is the problem that you started reading the haynes for?
Old Oct 14, 2006 | 05:55 AM
Acemandb's Avatar
Acemandb
Got one on my '94 labeled POWER POINT lower middle dash behind floor shifter.
Obviously intended as a 12 volt power supply for anything you might want to plug into it. As previously stated a cigarette lighter (female portion) without the lighter.
Shorted ? Probably at the receptical, good place to start looking.
Old Oct 14, 2006 | 07:31 AM
subford's Avatar
subford
Sounds like he is trying to plug 120 VAC items into the 12 VDC power source.
This is not what this is for.
Old Oct 14, 2006 | 07:40 AM
mikeyswood's Avatar
mikeyswood
From what you have described, I believe that you are refering to the flap to the left of the ash tray. That is, as previously stated, an additional female recepticle for any 12 vdc accessory. If there is a short I would also start by looking at the terminal first.
Mike
Old Oct 14, 2006 | 07:50 AM
alxsnmr's Avatar
alxsnmr
I do not believe 87 to 91 trucks came with power point as the 92 and later trucks refer to, as it was a 92 and later open cigeratte lighter port. Are you sure you are looking at the right wiring diagram. The haynes manual for those trucks has wiring diagrams for the various years, and variation with in model years. If you do not seem to know where the short is exactly, you may end up doing a wire trace by disassembling the whole truck as you go to find the short. It will not be fun work nor will it simply be a weekend project. Then again it may be just simple and easy to fix, one can never tell about finding shorts.
Old Oct 14, 2006 | 02:42 PM
Flatlanded87
I found it last night. My heater wasn't working (big problem because its already winter here), so I checked the fuses as I always do. I decided to pull each one of them out and look at them to make sure any haven't gone. The one fuse that was gone I had no clue what it did so I decided to check the haynes manual to see what it was for. It gave me the description of "Power Point". It has a dead short for sure, but if its as useless as you guys say it is, ill just leave it as it is.
Old Oct 14, 2006 | 05:39 PM
biggreentank's Avatar
biggreentank
I stuck a cell phone charger in my power point one time and it blew out both of the tail and brake lights! Go figure...
