Excursion Coil Spring conversion Sway bar issue
Old Oct 24, 2016 | 10:02 PM
hwybee22's Avatar
hwybee22
Originally Posted by Misky6.0
Depends what you mean, the '05+ SuperDuty with coil springs have 3" longer axles, larger brakes, wheels, and suspension.
So, to use the new bigger brakes, Ford changed to 17" (or larger) wheels in 05. The axles are also slightly longer (3 inches) so the backspacing on the wheels changed as well. So, it's mostly swapping components (with a few holes to drill/enlarge).
This is why you can't w/o using a spacer put '05+ wheels on the 99-04 SD or 00-05 Excursion.
This is 1 of the best write-ups with tons of pics on flickr
https://www.ford-trucks.com/forums/1...-write-up.html
Thanks Misky
Old Oct 24, 2016 | 10:39 PM
pirate4x4_camo's Avatar
pirate4x4_camo
I reused the factory Excursion sway bar and just moved it from the axle to the the frame but behind the axle.
Old Oct 24, 2016 | 10:41 PM
pirate4x4_camo
You can see the mounting plate here.
Old Oct 24, 2016 | 10:52 PM
pirate4x4_camo
Delete .......
Old Oct 29, 2016 | 05:25 AM
BatteryGuru's Avatar
BatteryGuru
Well I got the 05 bar. Was able to get it installed with the 2010 links. How ever there is very little clearance. It's actually touching on one side . I'm hoping when I set the truck down it will shift the radius arm back some . The 05 bar is larger diameter but not really that much shorter .
Old Oct 29, 2016 | 05:50 AM
5HUB's Avatar
5HUB
Did you get 05 Excursion or Super Duty away bar? I had similar issue, 05-07 Super Duty sway bar corrected it. This pic is when it was touching.
Old Oct 29, 2016 | 06:49 AM
BatteryGuru
Its supposed to be a Superduty bar. I definitely could not fit those extended end links.
Edit: It is a 05-07 bar SD bar but from 2wd. I was under the impression they were interchangeable. Well I guess they are but is the 4wd bar shorter on the ends?
Old Oct 29, 2016 | 07:59 AM
5HUB's Avatar
5HUB
Not sure on bar differences, this is how it changed with proper sway bar
Old Oct 29, 2016 | 08:03 AM
BatteryGuru
That is a dramatic difference!
Old Oct 29, 2016 | 03:24 PM
gots_a_sol's Avatar
gots_a_sol
I just looked at my truck and it looks like 5HUB's 2nd pic (I used a complete rolling chassis, so it would definitely be a stock 4wd bar)
Old Oct 29, 2016 | 08:34 PM
BatteryGuru
Ok. Thanks for the input everyone. I ordered a 4wd bar. Should have it in a few days.
Old Nov 2, 2016 | 05:32 PM
Blakshukvw's Avatar
Blakshukvw
So i gotta ask, how do your X's ride after the conversion?
Old Nov 5, 2016 | 12:31 PM
  #28
BatteryGuru
I will be able to tell you soon.
Just a follow up. The 4wd bar was the fix. Had to use the 2010 end links due to bolt size. I'll have to get extended 2010 links .Also to note the 2wd bar is quite a bit smaller in diameter
Old Nov 5, 2016 | 07:50 PM
  #29
5HUB's Avatar
5HUB
The quality is better but mostly depends on shocks and springs, the turning radius is amazing and I'd do swap for that alone. Bigger brakes is a plus.
Old Nov 5, 2016 | 08:30 PM
  #30
hwybee22's Avatar
hwybee22
This is probably my next mod and lifting the front should be cheaper now.
DMANDREWS
WTB - Parts & other
Dec 17, 2017 02:37 PM
1948Dev
Sep 4, 2017 09:32 PM
agsmv1
Mar 12, 2015 11:18 PM
jimcar-9
25
Apr 18, 2014 10:24 PM
riggz
Jul 26, 2007 06:46 PM
