'48 F-1 front sway bar
Old 09-03-2017, 08:37 PM
1948Dev's Avatar
1948Dev
1948Dev is offline
1948Dev has a good reputation on FTE.1948Dev has a good reputation on FTE.
I had Carolina Sway Bar bend one up per my design out of SAE 1045.
It's 1 1/8" and the frame mount bushings are from Moog.
I fabbed the sliding end links and the mounting plates.
She's now flat in the turns.
Sorry about the photo, I've got no rack to make life easy.
Old 09-03-2017, 10:42 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
Is it a solid bar, or hollow tubing? That's massive!
Old 09-03-2017, 11:58 PM
1948Dev's Avatar
1948Dev
1948Dev is offline
Solid 1 1/8" 1045 spring steel. At the end of the bar, at 5-degrees twist
it's about 370# of force.
Old 09-04-2017, 08:57 AM
tinman52
tinman52 is offline
Welder User
tinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputation
Nice! Got a better pic of the frame mounting location/bushings?
Old 09-04-2017, 09:12 AM
Moe Craig's Avatar
Moe Craig
Moe Craig is online now
Moe Craig is a name known to allMoe Craig is a name known to allMoe Craig is a name known to allMoe Craig is a name known to allMoe Craig is a name known to allMoe Craig is a name known to all
Can we see what your design drawing are?
Old 09-04-2017, 10:26 AM
1948Dev's Avatar
1948Dev
1948Dev is offline
For the two front bolt holes, I knocked out the factory rivets between the frame and the forward cross-member. (Plenty of other rivets holding the stuff together)
Old 09-04-2017, 10:29 AM
1948Dev's Avatar
1948Dev
1948Dev is offline
Maybe, I'll look in my binder and see how presentable they are........
Old 09-04-2017, 10:55 AM
1948Dev's Avatar
1948Dev
1948Dev is offline
Plates are mirror images of each other. (and obviously not the
finished product in these views)
Rough sketches below.....
Old 09-04-2017, 02:27 PM
electricmaniac's Avatar
electricmaniac
electricmaniac is offline
electricmaniac is starting off with a positive reputation.
Great Info 1948!
I have been looking for F-1 Front sway bar for a couple of weeks, and nothing but applications for Mustang/Pinto front end conversions. So...Thank you so much!
Seems to me there would be a lot of interest in this. Especially for softer front springs (Polyslip; remove nos. 3, 5 , 7; etc.) or even taller sidewall tires and stock height where you can end up with more body roll.
Looks like your bar goes between the springs and the frame? How does that work, since the sway bar is hit before the bump stop on hard bumps?? Or am I not seeing it right?
Also, looks like you are running stock springs, less the bottom-most one, which the mount plate takes the place?
Old 09-04-2017, 05:10 PM
1948Dev's Avatar
1948Dev
1948Dev is offline
No one makes a dedicated front bar that I could find. Quickor used to make one years ago but his specs are in the hard drive of their computer which crashed long ago.....
As far as my design- those sway bar frame mounts will never get touched, even though my front bump stops have been mashed almost flat over the last 65+ years. Even with the spring directly kissing the frame at that point, it looks like I've still got about 1/8" before the sway bar bracket gets tagged by the spring. I will replace the bump stops in the frame with new rubber though, needs to be done.
The spring pack is 8 leaf. Underneath the bottom segment is a 6-degree steel caster wedge, then the fabricated plate and then the I-beam.
Old 09-04-2017, 06:36 PM
electricmaniac
I noticed that smashed bump stop. Kinda of glad it is smashed to give your sway bar setup a good test of clearances.
I couldn't see the castor shim.. I am using 6 degrees too: the truck seems to like it a lot better by going down the road straight! Appreciate you mentioning the order (top to bottom) of bottom leaf, shim, plate, axle seat. I thought so, but was not sure. So I assume the thin edge of the shim lines up more or less with the front of the plate.
Old 09-04-2017, 09:32 PM
1948Dev's Avatar
1948Dev
1948Dev is offline
Yup. That's how it is.
These seem to drive particularly hideously without the high positive caster numbers.
Makes sense if you're running radials as the caster has got to be adjusted from the
bias-ply based numbers. (combating radial tires' inherent behavior of being negative
at speed)
LWW
06-04-2012 12:26 PM
Cracker 73
03-17-2010 07:02 PM
badbrad60
1999 to 2016 Super Duty
11-14-2006 03:36 PM
ymmv
04-07-2006 09:58 PM
e william
12-05-2005 08:20 AM
Quick Reply: '48 F-1 front sway bar
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
