Nut re-threading ?
Old Oct 22, 2016 | 07:17 AM
Steven Stocki's Avatar
Steven Stocki
Nut re-threading ?
Per the attachment, the "E" distance is .75 inches (3/4).
The nut that goes onto this bolt... I need to "re-thread" it as it won't go onto the bolt.
I did some research - should I be buying/using the 2nd attachment ? a 3/4 tap ?
Thanks
Old Oct 22, 2016 | 07:23 AM
TooManyToys.'s Avatar
TooManyToys.
And where does this nut and bolt come from?
Are you sure one is not metric?
Old Oct 22, 2016 | 07:53 AM
Steven Stocki
Thanks for the response.
I highlighted the bolt / nut in the picture below.
I understand it's suppose to be on tight however, even with a 48" breaker bar it won't move. Not sure what happened.
Old Oct 22, 2016 | 08:07 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Yes but, the -10 part refers to 10 threads per inch. Are you sure that's what the bolt threads are?
Also "rethreading" a nut to a different thread pitch isn't recommended, material was removed when the original threads were cut and even more will be removed when you make the second cut, leaving you with a seriously compromised fastener. Also (I have done this before) as the tap cuts the new threads, the chips it makes as it crosses the old threads will be oddly shaped an get in the cutting edges of the tap causing it to "gall", the second threads you cut will be smeared and rough with sections missing where the old and new threads cross. As TooManyToys was alluding too above, a 3/4 inch bolt is probably holding something pretty important together, be certain this bolt is just for looks and has very little pressure on it as it will not be anywhere near as strong as a proper 3/4 bolt and nut.
Old Oct 22, 2016 | 08:21 AM
Steven Stocki
What do you recommend ? Ford wants over $100 for a new bolt/thread.
Old Oct 22, 2016 | 08:24 AM
Per4mance's Avatar
Per4mance
A bigger bar. That gets torqued to 410 ft pounds
Old Oct 22, 2016 | 08:27 AM
TooManyToys.
First, if it's the bolt that was factory installed, then it's metric. Nothing assembled on vehicles for a very long time has been imperial. Trying to thread the nut imperial ain't going to help fitment to the factory bolt.
Are both the bolt and nut the exact same parts that came off the vehicle? How about removing both a seeing if it's been cross threaded.
The factory torque spec is 405lb-ft.
Old Oct 22, 2016 | 08:29 AM
TooManyToys.
A new Ford $100 bolt and nut that has the proper alloy and hardness if these are buggered up.
Old Oct 22, 2016 | 08:32 AM
Tideman's Avatar
Tideman
That says LH drive. Is it referring to the thread or the side it's on?
Old Oct 22, 2016 | 08:40 AM
Rusty Axlerod
Put the socket on the nut (not the bolt head) put a piece of pipe (24in should be enough but longer is ok) over the breaker bar, stand on the pipe and bounce a little. 1/2 drive or bigger and six point socket recommended. That thing is tight! The bolt and nut should be ok.
Old Oct 22, 2016 | 08:45 AM
Per4mance's Avatar
Per4mance
Sorry Jack, my memory is slipping. i have 4 vehicles I'm working on right now and the numbers are flying around in my head. He still needs a BFB...............LOL
Old Oct 22, 2016 | 08:48 AM
Steven Stocki
Appreciate the responses. Thanks
Old Oct 22, 2016 | 09:17 AM
04badford's Avatar
04badford
When in doubt , punt , take a close look at the threads if smoothed out then there's your issue , sometimes if not too flattened you can run a file into the deep thread to help the nut add a little WD for lube, you can always pull one off a wreak in the junk yard worse case, 100 bucks from the dealer is paying for somebody new phone
Old Oct 22, 2016 | 09:37 AM
TooManyToys.
Bill, I'm pulling that number out of my head, for one model year. You might be right too.
I've shown this before:
5lb-ft ain't gonna matter. Tough to check unless your calculating body weight vs leverage distance with a breaker bar.
Old Oct 22, 2016 | 02:28 PM
HT32BSX115's Avatar
HT32BSX115
Thanks
Howdy,
It might help a lot if you tell us what you're working on! Year model etc......
That picture you posted appears to be the "Track Bar" for a 4x4. And you can buy that bolt and nut for about $30 all over
The parts list you posted indicates an M20 nut
RRP:
$58.83
Your Price:
$27.59 (You save $31.24)
SKU:
TBB-KIT2-OEM
Brand:
MAXX-LIFT
Genuine Ford OEM Track Bar Bolt Kit LB 1999-2004 Ford Super Duty F250 and F350 4x4 Trucks
The Track Bar Bolt Kit includes bolt and nut for factory installed track bar mounting.
Qty. 1 - Part# W706345-S439 -M20 Shoulder Bolt
Qty. 1 - Part# N811886-S436 -M20x2.5 Flange Nut
Forget about buying a tap. If you have to run a tap through ANY suspension nut (or die on a suspension bolt) You should just replace them. You just don't have to go to FOMOCO for it. There's plenty of after market sources for Grade-8 nuts and bolts specifically made for suspension.
Regards,
Rick
