F150 grinding noise problem
Old Oct 22, 2016 | 05:01 AM
vandexa4's Avatar
vandexa4
2005 ford f150 Fx4 So last Friday I started hearing a grinding noise from the passenger side front of my truck. sounded like metal on metal. So I started rooting around and noticed that bottom ball joints were shot. so replaced bottom ball joints on both side. I aslo replaced wheel bearing hub assembly on both sides, still heard the grinding. So I noticed that both axles were slinging grease, so I replaced them on both sides. Still heard the grinding noise. So then I removed everything from the passenger side and noticed that the locking hub actuator was grinding both axle and the wheel bearing hub. So I just got done replacing that on the passenger side, put it all back together, and still grinding noise ringtones free. Also replaced the 4wd solenoid that they said gets water in it, and I replaced the check valve. And I put new Rotors and breaks. Does anyone have any other idea of what it could be? I'm driving my self crazy and going broke. Any help would be greatly appreciated.
Old Oct 24, 2016 | 08:19 PM
steve(ill)'s Avatar
steve(ill)
read page 1... do the tests...it is in the wheel end / engagement for 4 x 4
https://www.ford-trucks.com/forums/8...then-some.html
Old Oct 24, 2016 | 08:21 PM
steve(ill)'s Avatar
steve(ill)
try engaging the 4 x 4 and driving a short distance ( dirt road) and see if the problem goes away...... system can not "disengage" the wheel end fully to get back to 2 x 4.
resq302
Aug 21, 2018 10:29 AM
Jimbob321
Jun 4, 2017 09:06 PM
F350Man79
Mar 31, 2016 04:14 PM
caedo
37
Jun 4, 2014 03:06 PM
Chistoso
Apr 4, 2007 05:45 PM
