Searches
Old Oct 21, 2016 | 02:45 PM
'77 F100 Custom's Avatar
'77 F100 Custom
Searches
Hello, I'm new to this board, and have tried several searches for vacuum line schematics with no luck so far. If someone can steer me to a schematic for my little truck, I would be grateful. Thanks in advance.
I'm working on a 1977 F-100 Custom with 302/auto trans. No air. Has power steering and power brakes. Preciate it.
Old Oct 21, 2016 | 03:45 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
https://www.ford-trucks.com/forums/1...ml#post1522830
All I got, yea 351M, but might get you going.
Do you see the blue line with User CP, Albums, FAQ? See the SEARCH on that line? It has a drop down search menu arrow, go to the "Advanced Search" option, top left side (search block) type in there what you are looking for and then go to the lower right column and highlight 73-79 forum. Select it and then you will have a detailed search just in the 73-79 forums.
Old Oct 22, 2016 | 12:15 AM
dads1977's Avatar
dads1977
When I rebuilt my motor, and went to smog it for the great state of communistic California,
My smog tech was kind enough to provide me a copy for a Ca. 302 manual transmission / automatic sheet
(sorry 'bout the blue paint on the back)
Old Oct 22, 2016 | 04:45 AM
benbuilder's Avatar
benbuilder
77F100custom, PM me, I have some info that can help. A good guy from this site, Rougeriver, sent it to me when I was looking.
Old Oct 23, 2016 | 12:00 PM
'77 F100 Custom
Hey, thanks for the Ill., dads1977. Do you know if the non Cali trucks had the by-pass valves on them? My main concern is with hooking up the heated vacuum port on the rear of the intake to control the hot air door in the air cleaner, and also the proper hook up of the EGR vacuum ports.
Old Oct 23, 2016 | 12:01 PM
'77 F100 Custom
10-4. Message sent. Thanks for any help, bruddah.
DaisyF150
Jul 19, 2017 11:56 PM
dthut
Apr 3, 2016 01:16 PM
1978fordshort
Dec 8, 2013 10:46 AM
1930 Dodge
19
Dec 19, 2012 06:11 PM
zeke51
Feb 25, 2009 04:49 PM
