Tranny Issues?
Old Oct 26, 2016 | 03:44 PM
JEFFFAFA's Avatar
JEFFFAFA
Originally Posted by GaryKip
What is the adjustment procedure for that pin in the Vacuum modulator?
For a Bumpside C6 the factory one is part number C4AZ7A380A. 1.677" long. 1/8" diameter. From here Ford made a kit that came with that pin and 4 others of different lengths. For a C6 the part number was D8AZ7A380A. The longer the rod the later the tranny will shift. I just did a search and found below is what Bobby posted on a thread in 2015.
instig8r63
Quote:
Originally Posted by sweetlou1
Agreed. If you look at my last post I have a question about the other colored plug in type modulators. Do you know anything about those? The Trans Go 67 shift kit also isn't hard shifting at all. It is set at NO. 1. It shifts as it did before the install.
The shift points aren't bad, its just I want it to shift a little bit later.
Screw the little screw inside the vac mod clockwise 1-1/2 turns or install a slightly longer modulator rod. The different colored bands on the modulator indicate different rate springs inside the modulator. I like a black stripe modulator in my trans and I have the same shift kit. If you elect to change the modulator rod instead of adjusting the modulator valve, 1/16" longer modulator rod will increase the shift pattern a couple hundred RPMs at WOT.
Old Oct 26, 2016 | 04:04 PM
dfdiamond's Avatar
dfdiamond
Thanks so much for the detailed info! I will be out of town away from the truck for a few weeks so it will need to wait until I'm home mid November. I do appreciate this though and I'll keep you posted on what I find! I do know a trans fluid drain and fill is in the truck's future. Do any of you recommend replacing with a pan that has a drain plug, and any brand/item suggestions?
eigenvector
1983 - 2012 Ranger & B-Series
Jan 2, 2009 08:49 AM
medicbearusaf
Feb 4, 2007 02:08 PM
Mounter
Dec 15, 2006 10:19 AM
rverg
Jul 7, 2004 08:54 AM
TexasDeeva
Apr 17, 2004 02:16 PM
