That is the Fuel pump, and a common leak point. May need to just tighten the clamps back up or may need some new rubber lines. Worst case is you need a new fuel pump.
There may be no difference in the pump itself. The disc looking thing may be mounted to the banjo fitting. I'm on the east coast, so I've actually never run across a Cali truck.
