351w heads
Old Aug 22, 2003 | 11:29 PM
Chris_ce's Avatar
Chris_ce
351w heads
Picked up a rebuildable 351 from the junk yard today. It had e5ae heads. I've heard that the c9oe and the d0oe are better. So how much would I gain going with the c9 or d0 heads.
Old Aug 23, 2003 | 09:47 AM
jwtaylor's Avatar
jwtaylor
351w heads
I have E5AE-CA heads listed as 1985 302 heads so if they are 302 heads older 351 would be an improvement or one of the newer gt-40/gt-40p designs and run a little more than the c9 or do you mentioned. Going from a crappy stock to a little better stock will give you roughly 20-30 extra hp or that seems to be the rule of thumb. Just a thought, good luck
Old Aug 24, 2003 | 10:04 PM
quentrm250's Avatar
quentrm250
351w heads
Another thing to remember is that with the older 69 and 70 heads that you mentioned you will have to install hardened seats. Your best bet would be to either just use what you have or buy something better depending on your budget. Gt40 and Gt40p's would be a cheap improvement but better money spent than the 69 and 70's
Old Aug 25, 2003 | 01:39 AM
Crossfire's Avatar
Crossfire
351w heads
I agree with quentrm250; there is no point in digging up a 30 yr old set of castings and reworking them. A set of Windsor Jrs./Roush 180's are a better deal. GT40P heads have been shown to provide a 20+ hp increase on a 351 (over the C9/D0 heads) simply due to the better chamber design. In fact, those C9 and D0 heads have virtually the same exhaust flow as 302 heads even with the bigger valves.
Old Aug 25, 2003 | 01:46 AM
stepman's Avatar
stepman
351w heads
I have to disagree here but, that's just me. I think the 69's are better just because they aren't aluminum. They can stand a little porting and they should flow as good as the gt-40's but the best part is that they are more forgiving if you get them hot.
Old Aug 25, 2003 | 10:06 AM
BroncoDave's Avatar
BroncoDave
351w heads
Stepman:
Are you thinking about the GT-40X? I'm not really sure, but I think that's the aluminum one. The GT-40 and GT-40P are both cast iron. I have a set of the GT-40P's for my Bronco (not installed yet ) and I can assure you they are not aluminum.
I agree that the GT-40 or GT-40P heads are probably a better solution. I bought my GT-40P's on Ebay for $250.00, and they are ready to go. No fooling with hardened seats and overly high compression. For a good comparison on cast iron heads see the following link:
http://www.themustang-net.com/tech_articles/gt40p.shtml
Old Aug 26, 2003 | 08:38 AM
quentrm250's Avatar
quentrm250
351w heads
The gt40 and gt40p heads are both cast iron. Again I recommend not wasting money on old casting heads and put your money toward some more modern better designed heads. GT40P's will outflow 69 heads in stock form and are very cheap. Well worth the money.
Old Aug 26, 2003 | 11:08 PM
Chris_ce's Avatar
Chris_ce
351w heads
Iv'e been looking for the gt-40 on ebay but haven't had much luck yet.
Old Aug 27, 2003 | 07:20 AM
quentrm250's Avatar
quentrm250
351w heads
Well if you run across a single GT40-P head I have a brand new one I'd sell for $225 plus shipping. Complete with valves and springs. I had the springs tested once.......can't remember 100% for sure but I believe they were good to .550 lift.
Old Aug 27, 2003 | 02:47 PM
BroncoDave's Avatar
BroncoDave
351w heads
chris_ce:
I don't know if you are interested in a set of GT-40P's, but here is a link to a set on Ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33617
The seller is "fordpwr460"
This is where I purchased mine and everything was excellent. Mine were complete and this particular set is not, but he seems to have an almost limitless supply of them...
Good Luck!
Old Aug 28, 2003 | 12:27 AM
Brian460's Avatar
Brian460
351w heads
I am going to run a set of AFR 185 non-emission on my 351.
Old Aug 28, 2003 | 07:45 PM
Chris_ce's Avatar
Chris_ce
351w heads
Really don't want the p heads. Does anyone know what the gt-40 came out on? I want the ones with the angled spark plugs don't want to spend a fortune for headers.
Old Aug 28, 2003 | 07:54 PM
Chris_ce's Avatar
Chris_ce
351w heads
Do they even make headers for the gt-40p and to fit a bronco?
If so then who?
Old Aug 28, 2003 | 09:02 PM
Brian460's Avatar
Brian460
351w heads
I believe that Gen I Lightnings have GT-40 heads on them
Old Aug 28, 2003 | 09:12 PM
BroncoDave's Avatar
BroncoDave
351w heads
I'm fairly certain that the GT40 heads come from the Lightning engines.
Actually, I'm not aware of anyone that makes headers for the "P" head that are Bronco specific, and I have done some looking. Someone told me that Central Coast Mustang has some, but I have not been able to confirm that yet. There are some headers that certainly won't work without direct intervention from a ball-peen hammer, however Ford makes a set of stainless shorties for the Mustang that will work for either GT40 or GT40P heads (Ford Motorsport M-9430-P50)
http://store.summitracing.com/partde...M%2D9430%2DP50
How this will work in terms of exit angle from the Bronco engine compartment I am not sure.
I would prefer full length headers, so my plan (if I can not find a set that work) is to use 90 degree plug wire boots and install the plugs before the headers if necessary. If it's anything like other headers I've owned I'll be changing header gaskets more frequently than plugs anyway...
fordboy390
Aug 5, 2010 04:48 PM
SmokeBlower
May 27, 2007 06:51 AM
bigmik
Apr 19, 2007 07:58 PM
loudfords
Jun 13, 2006 11:14 AM
bluestang65
Feb 6, 2002 09:54 PM
