C9OE Heads dilema
Old Feb 6, 2002 | 07:06 PM
bluestang65's Avatar
bluestang65
C9OE Heads dilema
I just ordered heads for a 351W engine and I got C9OE castings accidentally (I wanted D0OE). However, as I understand it, they are better heads. My problem is compression. Does anyone know what the compression ratio would be for the D0OE vs the C9OE heads? Pistons are speed-pro flat top with valve reliefs. I need to know if they are going to break the bank with octane booster.
Old Feb 6, 2002 | 07:12 PM
bjoern's Avatar
bjoern
C9OE Heads dilema
Old Feb 6, 2002 | 09:54 PM
MrMotorsport's Avatar
MrMotorsport
C9OE Heads dilema
You should end up right at 10.5-to-1 to 10.7-to-1 compression, depending on which block you are using, gasket thickness, has the block been milled, have the heads been milled, etc. Chamber sizes on the C9 heads are virtually identical to the DOOE's......
Walwal44
May 2, 2014 08:28 PM
corner27
Oct 14, 2010 07:17 PM
biggman70f100
17
Jun 21, 2006 01:59 PM
loudfords
Jun 13, 2006 11:14 AM
Brian460
Jul 17, 2003 10:52 AM
