Start-up voltage
Old Oct 17, 2016 | 11:50 AM
NightTrain55's Avatar
NightTrain55
Start-up voltage
Two good batteries and glow plug relay. Brand new glow plugs. Turn key; voltage only reads about 9. Truck usually starts, volts stay that low for 30-40 seconds (lights are dim, accessories are slow). Then a slight "click"; volts come up to normal and everything is fine! What is it?? This issue makes for tough starting
Old Oct 17, 2016 | 11:55 AM
knottyrope's Avatar
knottyrope
Is volts on both batteries at 9? Glow plugs do draw 100 amps of so upon startup
If the drivers side isn't being pulled down then you might be running on one battery
Check the battery grounds to block and clean them, also make sure your pos cable is good.
Did you scrape the cable ends? lead corrosion is clear so you cant see it.
Old Oct 17, 2016 | 11:56 AM
oldbird1965's Avatar
oldbird1965
Its the glow plugs drawing juice for up to 90 seconds. I wouldn't think it should drop down to 9v though because these trucks take 10.5v to start.
Old Oct 17, 2016 | 01:25 PM
madpogue's Avatar
madpogue
What is the voltage AFTER the GPs shut off?
Are you measuring actual voltage at one of the batteries, or via a data read from the PCM? Or just guessing based on the dash gauge?
Old Oct 17, 2016 | 10:59 PM
NightTrain55
Just guessing from dash gauge this time. If she doesn't fire within first couple of tries, I will lose batteries
Old Oct 18, 2016 | 01:35 AM
madpogue's Avatar
madpogue
In that case, you need to LOAD test the batteries.
Jtpadilla1030
Jul 25, 2018 08:19 AM
1985L8000cat3208
Feb 1, 2016 08:38 AM
DieselVol
Sep 13, 2012 05:33 PM
guzzle92
17
Jan 12, 2006 06:39 PM
peterjeff
Electrical Systems/Wiring
Oct 17, 2004 11:20 PM
