Now _I_ have a Starting Problem!
Old Jan 11, 2006 | 03:11 PM
guzzle92's Avatar
guzzle92
The last two mornings I have had one heck of a time getting her to fire off. Not cold mornings, about 32º to 38º F. The first time, I figured it was due to just completing the hutch mod and had air in the lines or rails. I ran it around after starting yesterday for about 30 miles to make sure most of the air was out but it did it again this morning.
Symptoms:
TONS of white smoke while cranking from the pipe.
Seems to want to light on the second or third crank when turning over then just cranks again.
Once started and warmed, it will fire up immediately even with one battery disconnected.
Original Motocraft batteries:
battery voltage when sitting: 12.96 volts (both checked unhooked)
voltage at idle: 14.02v
voltage at 1100 rpm: 14.05v
I got it finally started by jumping with a partially discharged RV deep cycle battery out of the 5ver but still had to crank a bunch to get it to go. After warmed up, when I put the el-cheepo automatic battery charger on the batteries, it indicates a full charge in less than 45 seconds of charging.
I'm thinking batteries but they sure don't act bad.
Old Jan 11, 2006 | 03:55 PM
Kwikkordead's Avatar
Kwikkordead
Glow plugs are not getting hot. There's nothing else wrong.
Old Jan 11, 2006 | 04:05 PM
guzzle92's Avatar
guzzle92
I really didn't suspect that since I just checked the GPR 5 days ago but after posting the thread, I went out with the VOM and started checking voltages again. It did not appear as if I was getting voltage through the GPR at first. I disconnected the PCM side of the GPR and shorted it out to ground a few times and still did not seem to get anything through. Fiddled around with it some more and I could feel the relay energize and checked voltage again. VOM began to show 14+ volts. Put it all back together and checked voltage to the GP with the ignition and was showing 14+ volts for a very short time (engine warm). Terminals are all VERY clean so I don't suspect a corroded connection.
Ever hear of a GPR sticking!
Old Jan 11, 2006 | 06:13 PM
bilder12's Avatar
bilder12
are you checking the glow plugs themselves? I'm not an electrical engineer but is it possible to get power to the glow plug relay and not to the glow plugs and not show up on the meter? Try using the block heater two hours before lift off. If it starts up its a good bet its the glow plugs or even one causing the problem. I know if all the blue lights arent working at Kmart, the old girl wont shop.
Old Jan 11, 2006 | 06:19 PM
Kwikkordead
Just jump the two big posts of the relay tomorrow morning with a big screw driver for 30 seconds and have your wife hit the starter. It will start easily. That will also confirm a dead relay.
I can't stress enough how dependant a cold deisel engine is on a good strong functioning glow plug system to start easily.
Bunch of smoke and no start on a cold engine is a dead giveaway.
Old Jan 11, 2006 | 07:02 PM
guzzle92's Avatar
guzzle92
Just jump the two big posts of the relay tomorrow morning with a big screw driver for 30 seconds and have your wife hit the starter..............
Get the wife out of bed that early ....
What I will do is put the VOM on the GPR before I turn the key and see if I have anything there. If not, I do the sparkie-shortout thing for about 60 seconds and hit the key.
Old Jan 11, 2006 | 10:57 PM
Kwikkordead
Let us know how it goes. My wife is the same way. I dare NOT wake her up. She'll be grumpy all day.
Old Jan 12, 2006 | 08:06 AM
guzzle92's Avatar
guzzle92
Update:
I got up this am and immediately went out and put the VOM on the GPR. Turned the key on and nothing coming out of the GPR. Shorted out the terminals on the GPR (man does that screwdriver get hot!) but not long enough. Tried to fire, but just cranked. More white smoke. Went back around and started to short it out again and heard a "clunk" come from the GPR. Checked the voltage again and had voltage coming out of the GPR now. Cycled the key one more time and she lit right off.
I guess what I have is an intermittant GPR. When it is warm, it works fine. Get it cold and it won't.... (I think I burned my thumb on that d@*#
screwdriver ). Now back to searching the forum for a part number.
Old Jan 12, 2006 | 09:12 AM
marvinlong's Avatar
marvinlong
napa gpr-#109. mounting plate is a little different,but works great at $24.00.
Old Jan 12, 2006 | 09:21 AM
warrens250's Avatar
warrens250
Glad you found the problem. For future reference, the glow plugs drag down the battery voltage by at least one volt. Hook up a voltmeter to the battery, put it where you can see it, and turn on the key. You will instantly learn if the glo plugs are on without burning your finger on a hot screwdriver.
Warren
Old Jan 12, 2006 | 04:04 PM
guzzle92's Avatar
guzzle92
Originally Posted by warrens250
........ You will instantly learn if the glo plugs are on without burning your finger on a hot screwdriver.
Yea, but it was cold and I needed to warm up my fingers... Honestly tho, I new the relay was not working at that point and needed to get the truck running by shorting out the relay to try and get the GPs hot.
I was curious why the GPR would just quit all of a sudden like that, so after going to AutoZone and picking up a MR-99 relay ($14) I opened up the old one to do a little investigation. I was assuming that the contacts were just burned and no longer making good connection. I was wrong. The contacts were a little burned but the coil had just became so weak, it would not fully engage the contact plate. This explains why I could jar the GPR by tapping it pretty hard with a screwdriver and it would work - one time. Apparently it didn't go out all at once but has been working on kinkin' the bucket for some time.
Old Jan 12, 2006 | 05:17 PM
Kwikkordead
Glad you got it figured out.
Old Jan 12, 2006 | 05:19 PM
marvinlong's Avatar
marvinlong
glad you found one cheaper,will have to remember that!
Old Jan 12, 2006 | 05:33 PM
Miescha's Avatar
Miescha
Nice that there is one cheaper, but I thought the NAPA one was considered much better than stock - is that correct?
Old Jan 12, 2006 | 05:36 PM
Miescha's Avatar
Miescha
Hmmm, what if it does start (albeit somewhat slow but not out of the ordinary for these engines when cold and no synthetic oil) but there is white smoke (not tons though)?
I'm guessing GPR is working b/c it does start up - so maybe just one or two GPs are dead so not firing on all cylinders? Once ever (colder than usual outside) started but engine ran really rough and white smoke (not tons though).
Any ideas?
