Voltage Regulator Clicking, Voltage Drops
Old Oct 17, 2004 | 03:41 PM
peterjeff's Avatar
peterjeff
I have an 85 F250. I thought the truck wasn't starting because of air in the lines, but when i put a test light on the glow plugs (just to be sure they were working) they would cycle on & off every 3 or so seconds as i was hearing the voltage regulator click. CLICK, glow plugs on 3 seconds - CLICK glow plugs off 3 seconds, until the end of the glow plug cycle. The click is definitely coming from the voltage regulator. I know the voltage drops because I can hear it in the operation of my electric fuel pump. What's happening?
Old Oct 17, 2004 | 05:23 PM
peterjeff's Avatar
peterjeff
After more thorough observation: CLICK glow plugs on 2 secs. - CLICK glow plugs off 7 secs. - (repeat)
Old Oct 17, 2004 | 08:35 PM
Dealford's Avatar
Dealford
Isn't that a sign that some of the glow plugs are not working?
You might want to pull them out & test them for resistance?
AL.
Old Oct 17, 2004 | 11:20 PM
Franklin2's Avatar
Franklin2
I would measure the battery voltage during this cycling. If it goes up and down at the battery, then of course the battery has a problem. But I assume the battery is ok since the truck must crank over? It may be like Dealford said, and possibly one of the glowplugs is shorted, pulling the voltage down?
