Another Holley carb question
Old Oct 16, 2016 | 04:25 PM
bobs 80 f250's Avatar
bobs 80 f250
I have a Holley 4150 with the Percy's adjust-a-jet block. Sits on a performer 2171. Here's the problem,,,,,just started smelling gas when I make left hand turns! Can't find any leaks or puddling anywhere, either on the manifold or under the truck. Besides not making left hand turns,,,,,,anybody have any ideas?
Old Oct 16, 2016 | 04:31 PM
FuzzFace2's Avatar
FuzzFace2
What motor is in the truck?
What did you do with the tank(s) vents that run to the charcoal canister?
Did this just start after having carb & intake on the motor for some time?
Have you checked replaced the rubber fuel line from carb back to the tank(s)?
Dave ----
Old Oct 16, 2016 | 06:44 PM
bobs 80 f250
My fault. It's a 351M. Rebuilt the truck over a year ago. Removed the canister but not the tubing. Removed all the pollution controls. Been running this way since. Just started today out of the blue!
Old Oct 16, 2016 | 07:17 PM
FuzzFace2's Avatar
FuzzFace2
So what did you do to the tank vent lines to the canister?
They left open or did you plug them?
If open you were lucky up to now.
Dave ----
Old Oct 17, 2016 | 05:59 AM
bobs 80 f250
Can't find any leaks under the truck though. Maybe just venting through the tubing. I will try to plug up the hose and go from there. It kinda makes sense. The tubing is on the right side of truck, and filled the tank to max. Thanks
Old Oct 17, 2016 | 08:21 AM
FuzzFace2's Avatar
FuzzFace2
If you plug it make sure you have vented fuel caps or you run into other issues.
Dave - - - -
Old Oct 17, 2016 | 03:04 PM
Franklin2's Avatar
Franklin2
Plugging the lines from the carb can cause hard starting in hot weather also.
Old Oct 24, 2016 | 10:21 PM
bobs 80 f250
Finally after a period of not being able to work on my truck to locate the source of my fuel leak. I was able to locate the source. The rear bowl, on my Holley carb, has a screw where you can check fuel level,,,,,,it popped out!!!!! Was able to purchase a new sets(the only way I could purchase) and solved my problem. So it's safe to say my wife is correct! I have a screw loose!!!!!!
Old Oct 25, 2016 | 02:05 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
Glad you got it squared away. Our Wives must know each other !
CentralMassLandscape
Sep 17, 2011 08:33 PM
AntiHero55
Aug 28, 2010 09:11 PM
Pfeifferj
Jul 21, 2008 08:08 PM
Littlejon
Jul 16, 2008 08:09 AM
akfj62
Oct 21, 2005 09:06 AM
