Power steering update
Old Oct 15, 2016 | 08:12 PM
Garrett Killgore's Avatar
Garrett Killgore
So i did a full flush to my powersteering BUT now it only works to the left and not to the right. So now im really questioning why does it only work when i turn it left and not right?
Old Oct 15, 2016 | 09:13 PM
wtroger's Avatar
wtroger
Spool valve in steering gear is plugged / broke.
Old Oct 16, 2016 | 06:11 PM
85F350IDI's Avatar
85F350IDI
So would that mean a new steering gear box? If so any suggestions? How easy would it be to replace this spool valve
Old Oct 16, 2016 | 06:40 PM
Macrobb's Avatar
Macrobb
If you have the time(and no money), I'm sure you could rebuild your steering box.
Otherwise, a cheap Autozone or equivalent reman unit would be a quick fix.
You can swap one out in a couple of hours; note that jacking the front wheels off the ground so you can line up the radius arm(I think that's what it's called) with the spline on the new box will make your life easier.
Old Oct 16, 2016 | 07:00 PM
85F350IDI's Avatar
85F350IDI
Would it be the steering shaft? The radius arm goes from the knuckle/spindle to Frame
Old Oct 16, 2016 | 07:11 PM
Macrobb's Avatar
Macrobb
Looks like it's actually called a pitman arm. The arm which connects to the bottom of the steering box via a spline and nut.
The top side with the shaft isn't hard to work with, as the steering wheel spins (mostly) freely.
Feb 23, 2018 01:12 PM
jcoy405
Feb 22, 2016 10:39 PM
mr56effie
Jul 25, 2014 07:18 PM
brenthottle
Jul 11, 2014 06:02 PM
aayoakam
22
Jun 22, 2005 09:00 PM
