heater core
Old Oct 15, 2016 | 06:57 PM
lafermedavid's Avatar
lafermedavid
heater core
Heater for trucks and Broncos with High Output heater and NO air conditioning.
FORD MOTOR # E30Z-18476-A This is what the BG is selling ,it measures the same as my standard non high out put heater,any thoughts before i purchase
1978, 1979 Bronco
1973, 1974, 1975, 1976, 1977, 1978, 1979, F100, F150, F250, F350
Core Height : 7 1/4"
Core Width : 6 1/8"
Core Depth : 2"
Inlet : 5/8"
Outlet : 5/8"
This new replacement heater core is just what you need to get your vehicle in good running form again!
Specifications: •Replaces one of many dealer part numbers including: C6DE18476A, C6DE-18476-A, C6OZ18476B, C6OZ-18476-B, E30Z18476A, E30Z-18476-A •Core measurements: 7 1/4 x 6 1/8 x 2 inches •Inlet Tube Outside Diameter: 5/8" •Outlet Tube Outside Diameter: 5/8" •Direct replacement •
Old Oct 15, 2016 | 07:17 PM
lafermedavid
https://www.ford-trucks.com/forums/1...the-years.html Confirms BG is not high out put heater
Old Oct 15, 2016 | 07:34 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Older info from Ranger429
For any one looking for a brass/copper core Advanced Auto part number 398304 is the correct one. It is also the same core that fits early, 68'ish Mustangs. Laurel Mountain Mustang is where I bought mine from. Part number just in case it is needed in the future:
For A/C18476-1A
For non A/C18476-2
www.laurelmountainmustang.com/products/1973-79-bronco-heater-core-without-a-slash-c-brass
Also NAPA but makes sure and ask are they aluminum or copper? Copper is what you want. Heater core, high output heater C6OZ-18476-B
AntiqueAuto Supply, Arlington, TX (817) 275=2381
WesleyObsolete Parts, Liberty, KY (606) 787-5293
Dennis Carpenter, Concord, NC also has 1 but they have it listed under C60Z-18476-B, the third digit is "zero" instead of the correct letter "O". (704) 786-8139
Additional C6OZ-18476-B heater core applications:
1966/70 Falcon w/o A/C / 1966/72 Fairlane/Torino w/o A/C / 1971/73 Mustang/Cougar w/o A/C
Heater core w/ factory A/C or hi-low comfort vent system
D3TZ-18476-A
Std Heater core
D3TZ-18476-C
Old Nov 25, 2016 | 02:17 PM
lafermedavid
heater core
standard cab heater core (copper) Rock auto 30$ and some change
Old Nov 25, 2016 | 02:35 PM
54Hydro's Avatar
54Hydro
https://www.ford-trucks.com/forums/1...ur-pickup.html
Side by side comparison of a high output and a standard heater core and box. O'rielly Autoparts cores have a lifetime warranty, NAPA does not.
Old Nov 26, 2016 | 12:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by lafermedavid
Heater for trucks and Broncos with High Output heater and NO factory installed integral air conditioning.
FORD MOTOR # E3OZ-18476-A This is what the BG is selling, it measures the same as my standard non high out put heater. Any thoughts before I purchase?
Do not buy it, it won't fit properly!
In 1983, FoMoCo replaced the heater cores used on 1973/79 F100/350's and 1978/79 Bronco's with new heater cores that are different shapes than the originals.
Because the shapes were different, also required were heater core seal kits, that BG fails to mention!
1973/79 F100/350 & 1978/79 Bronco:
E3OZ-18476-A (replaced C6OZ-18476-B) .. High Output Heater Core / Obsolete
EODZ-18658-B .. Heater Core Seal Kit / Obsolete
E3TZ-18476-C (replaced D3TZ-18476-A) .. Heater Core-Use with factory installed integral A/C & Hi/Lo Comfort Vent System / Obsolete
E3TZ-18658-C .. Heater Core Seal Kit / Obsolete
E3TZ-18476-E (replaced D3TZ-18476-C) .. Heater Core-Use with standard heater and dealer installed A/C / Obsolete
All of these parts are obsolete, the cores are available NOS, but no one has the seal kits...which were required if replacing with an E3 heater core.
Post #3: Both Antique Auto Supply & Westley Obsolete Parts are no longer in business!
I don't know what happened to Antique Auto, but Westley was bought out by a guy who only sells on ebay and at swap meets.
Old Nov 26, 2016 | 01:49 PM
lafermedavid
seal kit
Thanks Bill,a guy on ebay has one with seal kit extreamly expensive,,,,guess Ill be adapting something I mainly wanted to let others know about( rock auto) copper core,,seems like alot of aluminum out there
Old Dec 2, 2016 | 02:06 AM
four-sixty-power's Avatar
four-sixty-power
Good info all around, I will be saving the seals from the heater cores that I find from now on!
Old Mar 14, 2017 | 01:44 AM
four-sixty-power
someone said to use the insulating foam for hot water pipes in houses/industrial, to make the seal around the heater core, I will have to try this if I run out of stock seals.
jiminn
Nov 30, 2020 02:07 PM
trooper73
Jun 18, 2019 09:24 AM
djjsc
Aug 12, 2017 09:35 AM
Bmoon1492
Jan 28, 2013 08:02 PM
atcrider1
Nov 15, 2012 10:31 AM
