Heater boxes same across the years?
Old Nov 11, 2013 | 12:02 AM
jgavac's Avatar
jgavac
The blower motor for the heater box in my 76 is making lots and lots of noise, and everything smells like coffee because some spilled.
I've got a fully "restored" heater box that I did up for my 79. New core, gaskets all around, etc etc. The only difference is the 79 has the extra heating core while the 76 does not.
Other than that minor difference, can I just swap the two out? Since I'm going to be tearing the dash apart, I just want to double check before I dive into it.
Thanks
Jameson
Old Nov 11, 2013 | 01:31 AM
montana_highboy's Avatar
montana_highboy
Originally Posted by jgavac
everything smells like coffee.
Starbucks may be interested in this "technology".
Old Nov 11, 2013 | 08:10 AM
lafermedavid's Avatar
lafermedavid
"The only difference is the 79 has the extra heating core",,,This is a 79 Im not sure what you mean extra heating core?
Old Nov 11, 2013 | 09:13 AM
mikeo0o0o0's Avatar
mikeo0o0o0
It will fit. The "high output" heater housing is a little different internally, that's to accommodate the larger heater core. On the outside they're the same. Should be a bolt in.
Oh, you will need to add this to your dash though .
Old Nov 11, 2013 | 09:21 AM
mikeo0o0o0's Avatar
mikeo0o0o0
You can see where the differences are in the last picture lafermedave posted, the one where it looks like he's getting ready to fill his housing with coffee too .
See how the space for the heater core stops short of being the full length of the opening? This is a standard heater core.
With the high output option the space is the same size as the opening, it doesn't have that overlap.
Old Nov 11, 2013 | 09:54 AM
lafermedavid
jameson
wow thats cool Mike,So the heater box I have is for standard heater core?
Old Nov 11, 2013 | 09:58 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Yup, it's for standard heat.
Old Nov 11, 2013 | 10:11 AM
lafermedavid
heater core
I love this site I learn something new everyday.
Old Nov 11, 2013 | 10:25 AM
jgavac's Avatar
jgavac
I put my mocha up on the dash while driving through town because I couldn't hold it and drive at the same time. When turning onto the highway, it tipped over and a third of it went down the vent before I could grab it
That high output heater badge is neat. I wonder how mmuch more heat this will give compared to the smaller variant. I've only got a 300, so I'm not expecting too much. I remember with the 460 in the 79, when that thing warmed up to full temp, the heat coming out was pretty damn hot
-Jameson
Old Nov 11, 2013 | 10:37 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Not a 100% sure but I believe the standard core is 6" long and the high output is 8".
Old Nov 11, 2013 | 10:40 AM
lafermedavid
HC
yep standard 6"
Old Nov 11, 2013 | 11:47 AM
mikeo0o0o0's Avatar
mikeo0o0o0
yep standard 6"
Thanks David, I knew the HO was 8", it's listed in the parts catalog but they didn't give a dimension for the "economy" version (that's what Ford calls it). On that one I was going on a very foggy 30 yr old memory from when I changed one in the Pumpkin back in the early 80's.
Old Nov 11, 2013 | 04:00 PM
VocaTexas's Avatar
VocaTexas
I'm still curious about this 'extra heating core'...
Old Nov 11, 2013 | 05:41 PM
jgavac's Avatar
jgavac
This is the standard (lafermedavid's photo). Notice the stop in the box, highlighted by the red circle
Now here is high output heater variant (actually my box ) Notice how there is no stop.
The the cores themselves. Standard
High output variant
-Jameson
Old Nov 11, 2013 | 06:56 PM
1972RedNeck's Avatar
1972RedNeck
If you want to look at a big heater core, find one out of a '67 - '72 chevy. A little old 350 can't keep up.
