6.0 having running issues
Old Oct 14, 2016 | 05:10 PM
psu927's Avatar
psu927
05 f350 with sct tuner (studded and deleted) with blue spring mod. And for the record I took the truck back to stock tune
Having an issue where after a long hard run, or a run up a hill, the truck starts running rough and acting like its not getting fuel. Sometimes it runs so bad it dies. Wait a few seconds, start her up and it runs fine. (until I do a hard pull again) I can hear a intermittent slight miss at idle as well at times. Tank is 3/4 full of fuel. No codes, no CEL. Also there is no smoke when this happens. just took her for a run and it happened, brought it back and shut it off, started it back up and idles fine.
Oil pressure seems good, can't remember exact numbers but it was in the 2000's I think even while it was dying. FICM voltage holds steady at 48 volts.
I changed the fuel pump and filter out to a different one. (a used one that was working when removed from a different truck) no change. I did not change the upper filter but it doesn't look bad.
I imagine a fuel pressure test would be in order but I do not have the equipment right now to do it. Am I right thinking its a fuel issue?
Old Oct 15, 2016 | 10:21 AM
psu927's Avatar
psu927
to the top
Old Oct 15, 2016 | 10:55 AM
lanneinbc's Avatar
lanneinbc
Sounds a lot like what we went through with ours recently. Turned out to be a faulty ICP sensor.
Old Oct 15, 2016 | 11:39 AM
psu927's Avatar
psu927
Did you have good guage readings?
Old Oct 15, 2016 | 12:56 PM
lanneinbc's Avatar
lanneinbc
I don't have any gauges yet, so I'm going from memory as to what my mechanic said. And I'm a total newb so take this fwiw. IIRC it was reading 350 with the engine off, meaning it was giving a higher reading than it was actually getting when the engine was running. Other systems were fooled by the artificially high number.
Old Oct 15, 2016 | 01:35 PM
WatsonR's Avatar
WatsonR
Use loner tools from Advance or Auto Zone
Old Oct 15, 2016 | 04:16 PM
psu927's Avatar
psu927
Pulled the tank. When I pulled the (blue) feed line it was stuffed full of crap. Pulled the pickup and the whole bottom is broken off. (was just 2 tubes going down, all the parts are in the tank) pretty sure that's my problem.
X-70STANG-F150
Jul 18, 2017 10:10 AM
gonnasellit
May 26, 2017 06:02 PM
JW1971
Nov 12, 2014 10:16 PM
JPSLLC
Oct 24, 2013 06:56 AM
bigbeariron
Jan 21, 2012 05:11 PM
