Quick swap
Old Oct 13, 2016 | 06:59 PM
B.Les's Avatar
B.Les
Quick swap
Ive got a '96 bronco with a 351. Its got 300k on the block and its started to eat itself, metal shavings etc. In my location its near impossible to find a 94 or later rolled block. And I have to pass emission testing where I am so I cant swap to a 5.0 without swapping electronics over too. However, older 351 blocks are a dime a dozen. The heads off my block are still good. If i get an older block, say an 80's model, and use my heads and all other parts, even though I lose the roller cam (not a big deal for me in this truck), will I run into anyother problems? I desperately need this truck back on the road. From the research I've done, I dont think there are any differences in the bottom end of the engine. Or at least any major difference that would matter. But before I dropped any money on buying an engine, I wanted to check with some other opinions first. Thanks.
Old Oct 13, 2016 | 07:11 PM
Conanski's Avatar
Conanski
Yes the bottom end is essentially the same except for the cam so a flat tappet block would work but I'd suggest you change the cam in whatever block you get to something that is known to be EFI compliant to ensure you pass the emissions tests. Also note you can put a roller cam in an early block you just need to use linkbar roller lifters and you will likely need custom pushrods.
Bmoodie10
Jun 19, 2018 01:15 PM
misterdave57
Oct 8, 2014 02:24 PM
mstrelectrician
Sep 20, 2007 12:18 PM
bron1967
Oct 22, 2004 12:40 AM
Freakazoid!
Mar 1, 2004 10:01 PM
