Draining coolant
Old Oct 16, 2016 | 07:11 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Draining coolant
Just pulled a good running 5.0 out of an 87 F250. It's going to be stored for a bit and the concern is that the previous owner was running straight water as the coolant. It gets pretty cold up here and the engine will be in unheated storage. Of course, drained the rad during disassembly and tipped the engine enough to run what I could out the hoses. I don't think this should give me any problems with freezing up, but anybody have any knowledge of possible pockets in the block that might not drain?
Old Oct 17, 2016 | 02:21 AM
xlt4wd90's Avatar
xlt4wd90
There should be a pipe plug near the base of each side of the block that you can open up to fully drain the water jackets. On the passenger side, it's near the front. while it's near the rear on the driver's side.
SoCalAngler
Oct 18, 2016 10:23 AM
Metz22
Nov 19, 2015 07:13 AM
97ExpGuy
Apr 23, 2009 10:01 AM
renoduckman
16
Mar 3, 2009 06:22 PM
wavinwayne
Sep 20, 2005 06:09 PM
