Sponsored by: Real Truck
Radius arm drop bracket issues
Old Oct 13, 2016 | 07:53 AM
Rob_82's Avatar
Rob_82
Hey guys I'm experiencing a rather loud metallic clunking from my radius arm drop brackets, I have a 2016 f250 4x4 with a 3 inch lift, I didn't initially install drop brackets on the radius arms, when I took it into the alignment shop after installing the lift the tech there told me I needed them to reset the caster properly, so I ordered up the procomp drop brackets installed them and ever since then I am experiencing the clunking when going over decent bumps like speed bumps or the small curb turning into my driveway both forward and in reverse, it especially happens when turning over the bumps. I have double checked that they were install correctly and have double checked all bolts are torqued properly. I have reached out to procomp with this same info and am awaiting a response from them, I figured with the wealth of knowledge and experience here I'd ask see if anyone has experienced this as well and how it was corrected thanks for the input guys
SneakyF350
Apr 4, 2008 11:45 PM
midcal48
Jan 7, 2008 08:13 PM
Brian794x4
Oct 19, 2006 05:51 PM
SoArkSI
Jan 17, 2006 05:50 PM
DANA60
Sep 10, 2004 10:20 PM
