radius arm drop brackets
Old Dec 18, 2007 | 11:39 PM
midcal48's Avatar
midcal48
I have a 1978 ford f150 4wd and i recently installed a 4" lift kit from Rough Country. The kit came with the 7 degree C bushings but it still seems like my truck has a slight rake and sits lower in the front. Should i install some radius arm drop brackets?
What about a drop pittman arm?
Old Dec 19, 2007 | 02:11 AM
greythorn3's Avatar
greythorn3
drop bracket will only correct the radius arm angles.. i dont think it will lift it at all.
ray
greythorn3's Avatar
greythorn3
try some coil spring spacers maybe... somone might make them for that truck
Ray
Old Dec 19, 2007 | 05:08 PM
NOCO77's Avatar
NOCO77
Ray is right - neither of those items will have any effect on lift. Better driveability, maybe. If you drop the radius arms, you'll likely need to change the C-bushings again. If it were me (and it was once) I'd work on lowering the rear to level it in - much easier and 4" is plenty for a lot of tire choices.
Old Dec 19, 2007 | 06:31 PM
STGFordCrazy04's Avatar
STGFordCrazy04
The only thing that will lift the front of the truck is either new coil springs or something like the twist in coil spring spacers. I do not recommend the spacers because in my case on a 96 ranger I had they made the tires toe in and eventually chewed them up. Maybe it wasnt all my problem but removing them from the 3" coils helped out an awful lot. Id go along with NOC and remove the 3" factory block and install a 2" block or maybe even none at all. My prefference is a truck that sits lower in the back than the front.
Old Dec 24, 2007 | 08:21 PM
7fords's Avatar
7fords
If you use the truck for hauling you will want the rear to sit higher so that when you have a load you arent shining for coon with your lights
Old Dec 24, 2007 | 08:32 PM
monsterbaby's Avatar
monsterbaby
depending on how much higher the rear is and if your not worried about it being loaded and sitting nose up then take the factory blocks out of the rear this will drop you about 2" in the rear and usually level the truck.
Old Dec 24, 2007 | 09:21 PM
ranger429's Avatar
ranger429
Drop the coil spring buckets down up front 2", no cost and very simple to do to level it out.
You should also get a drop pitman arm for a 4" lift.
Old Jan 6, 2008 | 07:24 PM
midcal48's Avatar
midcal48
How would i go about dropping the coil spring buckets?
And how much of a drop pitman arm would i need?
Old Jan 6, 2008 | 07:31 PM
STGFordCrazy04
Dropping the coil buckets is a cheap method of lifting the truck. It works but I just wouldnt do it to my truck. The coil buckets are held on by 4 bolts that run through the frame and bolt into the motor towers. Unbolt the buckets completely and reinstall with the top bucket bolt hole lined up with the bottom frame hole. Then the bottom bucket hole will be hanging below the frame. I have seen people use 1 1/2x 3 Angle iron bolted and welded to the bottom of the frame and 2 holes drilled to line up with remaining holes in the bucket. This will give you 3-4"
I hope you understand. I think I even confused myself!
Old Jan 7, 2008 | 10:04 AM
greythorn3's Avatar
greythorn3
you cheap SOB! i might have to try that! thanks for the cheap TRICK!!
Ray
Old Jan 7, 2008 | 11:39 AM
STGFordCrazy04
Ray,
not sure if thats a compliment or a cuss?
Old Jan 7, 2008 | 08:13 PM
greythorn3's Avatar
greythorn3
compliment! always better to think with your mind then your wallet!
Ray
Daniel Latham
Feb 21, 2017 09:39 AM
94xlt150
Mar 9, 2015 06:51 PM
mbxmitch
Offroad & 4x4
Dec 19, 2011 09:53 PM
OffRoadF-150
Offroad & 4x4
Dec 29, 2005 03:57 PM
DANA60
Sep 10, 2004 10:20 PM
