Dumb Question - Fill Radiator
Old Oct 11, 2016 | 05:27 PM
Codelizard's Avatar
Codelizard
So I'm outside right now putting in the new radiator... so.. dumb question..
How the heck do I fill this thing back up? I've never had a radiator without a cap before...
Aprox 16 quarts of coolant drained when I removed the lower hose..
How do I fill it properly...
I'll come in when the rad is in, to see if someone has taken mercy on me and shown me the way
Old Oct 11, 2016 | 05:33 PM
SmackDaddy's Avatar
SmackDaddy
Through the degas bottle.
Old Oct 11, 2016 | 05:35 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
^^^ x2. Different motor than you but same style without a cap. Fill the degas bottle to the max then run the motor. Be sure to cycle the heaters on as well so you can ensure the heater core is filled up as well, then top off as necessary.
Old Oct 12, 2016 | 12:06 AM
Codelizard's Avatar
Codelizard
Success! I drained approximately 16 qts when I removed the radiator, and put nearly the exact same amount back in!
Though, of course, I went for a ride once everything was said and done, and got a flat tire... at 11:30 at night... just my luck, eh?
Old Oct 12, 2016 | 12:07 AM
Codelizard's Avatar
Codelizard
BTW, thanks everyone for the assist!! And if you have a 2005 Excursion, buy one of the quick-disconnect tools from Amazon before your radiator goes bad.
Old Oct 17, 2016 | 11:45 AM
Stewart_H's Avatar
Stewart_H
Quick disconnect tool for what, exactly?
Stewart
Old Oct 17, 2016 | 01:58 PM
R&T Babich's Avatar
R&T Babich
Stewart
He may be talking about ring clamp pliers.
I replace the rings with stainless clamps from McMaster which have a nice housing around the screw.
Old Oct 17, 2016 | 06:19 PM
Codelizard's Avatar
Codelizard
No... the radiators on the excursion also process transmission fluid. There are 2 connectors on the bottom of the radiator (in and out) for these lines.
In the < 2005 models, this is a standard screw-in connector. Two wrenches and Bob's your uncle.
For the 2005 Excursion, they switched to a quick-disconnect connector that requires a special tool to disconnect the lines. Here's a link to the one that I bought:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Same for the other Super Duty trucks 2005 (and some newer)..
Old Oct 17, 2016 | 06:25 PM
Codelizard's Avatar
Codelizard
And a pic:
Old Oct 17, 2016 | 07:34 PM
Misky6.0's Avatar
Misky6.0
That same type tool is required to change fuel filters on 2004 explorers too. spending $10 for tools (or the $22 version you bought) to do a job are almost something to celebrate!!!
little dutch
26
Dec 27, 2022 05:43 AM
QuercusRubra
Mar 2, 2015 01:59 AM
cpnhgnjnky
6.4L Power Stroke Diesel
Mar 1, 2012 01:26 PM
NtShade
19
Oct 10, 2011 07:12 AM
amsuco
Oct 31, 2004 07:41 AM
