Simple Radiator Question
Old Oct 27, 2004 | 10:26 PM
amsuco's Avatar
amsuco
I just took my "new" 1993 Ford F-150 Supercab (302/auto trans) in for an oil change. The guys pointed something out. I seem to have a crudely plugged off outlet near the top of my radiator, and they don't have any idea what it's for. Neither do I.
Right below the radiator cap is the overflow hose. Immediately below that is the opening in question. It's so close to the top of the radiator that it looks like it is still a part of the neck of the radiator. That poorly-done plug is leaking. I need to find out what the opening is for so that I can decide whether to cap it correctly or reconnect it to wherever it's supposed to go. Does anybody have the answer as to just what this opening on the radiator is for? Thanks!
Ron
Old Oct 27, 2004 | 11:12 PM
Steina's Avatar
Steina
CO River Rat
Ron -
Some radiators have an inlet for heater return, rather than to the block. Do you know if the radiator in your '93 is original? Does the nipple look like it was added after-the-fact?
Steve
Old Oct 28, 2004 | 12:52 AM
Overkill-F1's Avatar
Overkill-F1
Your not talking about the connection for the auto trannie cooling lines are you? ...Terry
Old Oct 28, 2004 | 09:53 PM
amsuco's Avatar
amsuco
Mystery Solved
Thanks for the help guys! It turns out that this is an aftermarket radiator. The extra opening that they built in is nothing that I need for my application. Now I can cap it right and forget about it.
Ron
Old Oct 28, 2004 | 10:12 PM
Steina's Avatar
Steina
CO River Rat
Ron -
Does your '93 have AC? If it does, I'm wondering if the person who replaced the radiator went "cheap-charlie" and didn't get one with the right # of tubes (rows).
Steve
Old Oct 29, 2004 | 11:41 PM
amsuco's Avatar
amsuco
I can't say whether the aftermarket radiator is worse, the same, or better than factory. But the extra opening in it is now plugged correctly. No more leaks. The A/C, heat, and the temp that the engine is running at all look fine. Life is good again! Thanks again for the input.
Ron
Old Oct 30, 2004 | 01:30 PM
5_labsownus's Avatar
5_labsownus
Some aftermarkets are made with options for cooling oil or tranny fluid and some have a place for a temp. switch/sensor!
Old Oct 31, 2004 | 07:41 AM
peppy's Avatar
peppy
Mine has the exact same thing. I have a radiator hose type cap and clamp on it.
Thats kinda odd though....mine came with the cover and the clamp from the factory.
