Starter problems
Old Oct 11, 2016 | 03:29 AM
1996 F-350's Avatar
1996 F-350
Starter problems
Hey guys, new to this site and new to powerstroke. But anyways, im having a problem with my starter. Most times it starts right up but every now and then (more often when hot) the starter will spin but not engage. Any ideas on a possible solution? Thanks
Old Oct 11, 2016 | 09:18 AM
madpogue's Avatar
madpogue
Automatic or manual transmission? Does it grind when it fails to engage, or do you just get the electric motor spinning sound?
Old Oct 11, 2016 | 09:33 AM
knottyrope's Avatar
knottyrope
Automatic, remove inspection plate and see if flywheel is straight when cranking
Either one, remove all battery terminals and scrape inside and scrape the posts with a knife to remove invisible lead corrosion. remove starter wire and clean connection. remove engine grounds on front and clean them up too.
If it persists after then a new starter Is needed.
Rockauto.com has a new TYC SD gear reduction style for about 115 bucks shipped
Old Oct 11, 2016 | 11:21 AM
1996 F-350's Avatar
1996 F-350
It is an automatic and alright cool I will try that, thanks guys
Old Oct 12, 2016 | 09:17 AM
helifixer's Avatar
helifixer
if you order a starter for an '03 7.3 you will get the high torque starter.
Old Oct 12, 2016 | 09:26 AM
knottyrope's Avatar
knottyrope
wish I had known that prior to ordering mine,
Old Oct 12, 2016 | 08:21 PM
helifixer's Avatar
helifixer
every 7.3 that comes in my shop for a starter gets one
Old Oct 16, 2016 | 06:00 AM
PSU4ME's Avatar
PSU4ME
We put on the HD starter from summit racing and it makes a big difference. Turns it over like it's nothing.
Old Oct 16, 2016 | 02:34 PM
nateairman's Avatar
nateairman
https://www.amazon.com/TYC-1-06669-F...ype=automotive
is this the correct starter?
Funke1
Nov 26, 2015 08:54 AM
frankenford 66
Sep 8, 2013 12:24 PM
mmuenchow
Mar 29, 2010 04:48 PM
russkiypenguin
Nov 4, 2004 10:25 PM
theCroch
Nov 7, 2003 09:25 PM
