Headlight issue
Old Oct 10, 2016 | 10:55 AM
Gator4855's Avatar
Gator4855
Headlight issue
I am having a headlight issue on my 2000 excursion. In low beam mode only one light works. In high beam mode, only the opposite light works. However, if you pull the lever back for temporary highbeams… Both lights work. One in highbeam and one in low. Not exactly sure where to start on this one. Suggestions?
Old Oct 10, 2016 | 12:56 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
My first inclination is to swap bulbs and see if the problem follows or if it's something in the wiring.
Old Oct 10, 2016 | 01:11 PM
Stewart_H's Avatar
Stewart_H
Sounds like the low beam light that works, has the high beam element burned out, and vice versa for the other light.
Both high and low beams activate and light up when you pull back on the lever because that is the function for that mode, it activates low and high at the same time.
Stewart
Old Oct 14, 2016 | 03:11 PM
Gator4855's Avatar
Gator4855
Just got a chance to start working on this. Did the obvious thing first. Switched the bulbs. Got The same result.
Old Oct 14, 2016 | 07:43 PM
Stewart_H's Avatar
Stewart_H
What does that mean? Are you saying the same light that had the low beam out, still has the low beam out after the switch? Or are you saying the side that had the low beam out is still out, after the switch?
Stewart
Old Oct 14, 2016 | 09:14 PM
HiZ's Avatar
HiZ
My old X had an off the books wiring for the H/L light left and right
Under the hood in the power distribution panel. check all fuses and trace back
Also test wiring at back side of the connection.
2003EXV10
Jun 28, 2019 12:13 AM
2010f3504x4
Feb 8, 2019 01:56 PM
DeadFife
Apr 28, 2017 07:12 PM
homer4.2
Dec 11, 2009 03:33 AM
Dj300ford
Aerostar
Dec 13, 2003 02:17 AM
