2.8L Rebuild
Old Aug 22, 2003 | 02:23 PM
Bronco2Nic's Avatar
Bronco2Nic
Question 2.8L Rebuild
I am currently rebuilding a 2.8L V6 from an 85 Bronco II. The engine leaked and burned a lot of oil so everything is coated in a thick layer of oil. Right now it is completly disassmbled so I was just wondering what would be a good cleaner I could get that doesnt cost a lot. A friend of my brothers said that I should use paint thinner but I dont know if he was serious or not. I was just wondering if somebody could help me with this. It would be much appreciated.
Old Aug 23, 2003 | 05:23 PM
NorthernFord's Avatar
NorthernFord
2.8L Rebuild
yeah you probably could use paint thinner, but you'd be better off buying a pail of engine degreaser or parts cleaner(not brake cleaner) and using an old paint brush and brushing it on and then rinsing it off with water.
Old Aug 25, 2003 | 09:57 PM
BLAZING's Avatar
BLAZING
2.8L Rebuild
Is brake cleaner bad for use as a cleaner because if it is im screwed!
Old Aug 25, 2003 | 10:00 PM
NorthernFord
2.8L Rebuild
not it's not a bad thing to use, there are just better products to use than brake cleaner.
Old Aug 25, 2003 | 10:01 PM
NorthernFord
2.8L Rebuild
not it's not a bad thing to use, there are just better products to use than brake cleaner. just make sure use some quality assembly lube if you sprayed down the engine internals with brake cleaner
dnachristen
Bronco II
Feb 14, 2008 06:32 PM
bronco2454
Bronco II
Jun 5, 2006 02:33 PM
B'II-Trapper
Bronco II
Mar 18, 2006 08:13 PM
Bronco2Nic
Bronco II
Feb 7, 2004 06:05 PM
freejay
May 25, 2003 06:19 PM
