Bronco II Ford Bronco II
Grease Question
Old Feb 7, 2004 | 12:29 AM
Bronco2Nic's Avatar
Bronco2Nic
Question Grease Question
I'm finally putting my engine ('85 2.8L V6) back together and i'm wondering which lubricant would be better to use. I dont want to buy any new stuff so I have two to choose from. there is
A) White, Lithium based grease
or
B) Black, Oil based, Bearing grease.
that you for any help
Old Feb 7, 2004 | 02:41 PM
rebocardo's Avatar
rebocardo
Because it is designed for high temp and high pressure, which is what is found in your engine.
Old Feb 7, 2004 | 05:10 PM
GrayRanger4x4's Avatar
GrayRanger4x4
If you are put your engine back together then use the White, Lithium based grease.That is what it is designed for.We use it when we put our race engines back together and never han a promlem,the bearing grease is just that, for Bearings,not for engine assembly.
Old Feb 7, 2004 | 06:05 PM
Ken00's Avatar
Ken00
They make a lube just for that, check your parts store.
aphotic26
Sep 11, 2021 05:37 PM
LeoJr
15
Nov 30, 2013 04:30 PM
mechelement
Sep 12, 2010 09:49 AM
expy37at
Dec 5, 2006 08:33 PM
omni
Garage & Workshop
Jan 12, 2005 07:37 PM
