Help...
Old Oct 7, 2016 | 01:44 AM
Davefordguy's Avatar
Davefordguy
Help...
This is my baby. And as you can see I recently broke passenger inner and outer front axel shafts. I have rebuilt the front end, but now neither hub will lock they are acting like they are in a bind. I don't know much about them what could I have done wrong for them to work fine before I broke the axel to now they won't turn to engage
Old Oct 7, 2016 | 03:16 AM
77 1/2 F250's Avatar
77 1/2 F250
Bad things happen when that u-joint gives out unexpectedly.
I'd pull the front cover off the differential and see what may have gotten tweaked in the Dana 44.
Robert
Old Oct 7, 2016 | 03:30 AM
Davefordguy
Robert
I did all of the above during rebuild checked for play in differential and checked backlash to see if anything goes was twisted or warped nothing was off new seal and new oil put back cleaned hubs and put new grease the hubs wont turn to lock in can engage 4x4 and everything going turns freely just no wheel turn hubs wont go I to lock posistion
Old Oct 7, 2016 | 11:29 AM
650's Avatar
650
Did you put too much grease in the hubs? You can basically hydrolock it if you did.
Old Oct 7, 2016 | 12:25 PM
Davefordguy
I don't know could be they slide fine with hub key off but act as if they are hitting metal once so far. This might be a dumb question but I tore the front end down over a month ago and the parts got moved arround is it possible that the parts are side specific?
Old Oct 7, 2016 | 04:28 PM
650's Avatar
650
There shouldnt be any thing side specific for the hubs to my knoweladge.
I put too much grease in the hubs on my 76 Ford and it kept it from being able to lock in. Id also tear the hubs back off and check that all the splines are good and not binding.
Old Oct 7, 2016 | 04:31 PM
Davefordguy
Thank u for that tip I gave up and have some mile maker hubs on the way gonna clean put new and go sparingly on grease
Old Oct 7, 2016 | 04:40 PM
blackjack33's Avatar
blackjack33
Did you get the hubs put back together correctly?
+1 on going easy on the grease.
Old Oct 7, 2016 | 04:47 PM
Davefordguy
Yes but mine are model 60 and don't have the spring retainer ring
Old Oct 7, 2016 | 05:00 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Your "About Me" profile says 1978 F150 which came with a Dana 44 front driving axle. 1975/96 F150's have 5 lug wheels on a 5.50" bolt circle.
Dana 60's were only installed in some F250 4WD's and all 1979 F350 4WD's. These trucks have 8 lug wheels on a 6.50" bolt circle.
SDElwood
Jan 7, 2015 01:14 PM
ccarrier
Aug 20, 2010 08:39 AM
afreemanmd
Aug 2, 2010 05:38 PM
amaviper
Aerostar
Jul 18, 2008 08:55 PM
79-400-POWER
Aug 16, 2007 03:27 PM
