FI tech fuel supply question
Old Oct 6, 2016 | 11:00 AM
ktm4012's Avatar
ktm4012
I'm sure a lot of past posts about this but what are others using for fuel supply on the FItech EFI? The fuel command gizmo is back ordered till december. Any alternatives as far as fuel pump and return line? I have no problem routing a return line but not sure of the easiest way to run through the tank.
Old Oct 6, 2016 | 11:25 AM
Heliguy's Avatar
Heliguy
I went through this issue a while back. What I did was use the stock fuel lines and pickup tube as the return and then had to add a some AN fittings and hose in conjunction with Holly's HydroMat as a new pickup. Don't try to use the stock lines and pickup tube as your supply line, it will not work and youll have to redo it any ways. Check out my thread for pictures of how I did mine. Heads up, the fuel supply issue is the hardest part of adding the FiTech, the rest is fairly easy. Youll be happy when its done, mine starts right up and runs as good as my new vehicles. It starts so fast that it takes just a bump of the key, and in the beginning I was grinding the starter a little. I added remote start to mike too, works every time with FI.
Old Oct 6, 2016 | 11:52 AM
AK FORD GUY's Avatar
AK FORD GUY
I ran 3/8 fuel and return lines and used the FiTech inline pump. I also added an in-tank pusher pump to help get the fuel out of the tank (not sure it was needed though).
I wish my system was running as good as Heliguy's. I am working through a problematic cold start / warm-up issue. It would barely start and once it did, it would chug along at 350 RPMs and slowly raise up as it warmed up, all the while burning extremely rich.
This summer it has started up pretty well, but still a bit rich.
It is starting to cool off, so we'll see how it does in a month or so.
Even with the issues, I am still pretty happy. I am sure most of the issues are user error, but FiTech has not been able to come up with any real "solutions" yet, nor tell me what I did wrong. One of their tech's mentioned hooking up some sort of a solenoid valve to allow a vac port to pull more air in than what the IAC will allow. Honestly, that sounds like a Band-Aid fix. Everyone else seems to be having a stellar experience. This seems to be par for my course...
Old Oct 6, 2016 | 12:18 PM
EP145's Avatar
EP145
I used a factory in tank high pressure with my EFI and have 14k miles on it with no problems.
https://www.ford-trucks.com/forums/1...fi-swap-4.html
Old Oct 6, 2016 | 12:34 PM
jbehuniak's Avatar
jbehuniak
Uh-oh youre going FiTECH?!!!!!
Old Oct 6, 2016 | 12:37 PM
HIO Silver's Avatar
HIO Silver
Your post doesn't help anyone...
STATE YOUR POINT.
Old Oct 6, 2016 | 12:57 PM
jbehuniak's Avatar
jbehuniak
He's local (in CT) and its a vague way of cheering him on and showing my sheer jealously while subscribing with the proper amount of characters. I am excited for this and hope to learn from the swap.
Old Oct 6, 2016 | 01:36 PM
HIO Silver's Avatar
HIO Silver
Thanks for the clarification... sometimes the web isn't clear in translating intent or sarcasm ya know? I suppose that's why emoticons and emojis were invented.
Old Oct 6, 2016 | 03:48 PM
ktm4012's Avatar
ktm4012
Not sure yet John, I'm in the research phase LOL.
Old Oct 6, 2016 | 04:53 PM
hivoltj's Avatar
hivoltj
I'm running Fitech with a TanksInc in tank setup. The 255 lph walbro and LS fuel line kit works perfect.
My only gripe about the FiTech is getting transient fueling (accel pump) and cold start has proved difficult. These areas don't seem to "self tune"
Beats the crap out of a carb any day
Old Oct 6, 2016 | 05:12 PM
AK FORD GUY
Good to hear. if either of my pumps die, I will probably go this route. One high pressure in-tank pump and be done with it.
I have noticed the same issue with cold starts. This I really want to get figured out because that was one of the main reasons for my swap.
Old Oct 6, 2016 | 07:53 PM
jbehuniak's Avatar
jbehuniak
By the end of the month I hope to be in possession of the FiTECH, fuel system and hooking it up.
Between hivoltage ak and the other people who did the swap we should have a good list of how to do it a few ways. What works and what might work better. Sorry for hijacking I'm excited to order it shortly.
Old Oct 7, 2016 | 05:38 PM
hivoltj's Avatar
hivoltj
Hey guys, I started a Fitech thread in the fuel injection, carb and fuel system forum. Please come in and add your info
Old Oct 7, 2016 | 05:46 PM
AK FORD GUY
Sweet, good plan.
brk300
May 1, 2016 08:37 PM
Crock Pot
Sep 29, 2014 10:10 AM
osage
Jul 21, 2013 08:45 PM
Burdsnest
May 21, 2012 08:59 AM
LariatF350
Mar 3, 2010 02:17 PM
