Aerostar Ford Aerostar
Cardone Half Shafts
Old Jul 16, 2008 | 09:34 PM
amaviper's Avatar
amaviper
Cardone Half Shafts
Just received my half shafts from RockAuto and they look like they have been on a car already. Both the zip ties were cut and there is dirty grease in the splines. Also dings and scratches on one "cone". That going to affect anything? What do you guys think?
Old Jul 16, 2008 | 09:47 PM
amaviper's Avatar
amaviper
How do you delete a post ? Had pictures in both posts and then combined..
Old Jul 17, 2008 | 02:22 AM
rebocardo's Avatar
rebocardo
Yes, looks used. Probably someone bought it, installed it, drove it, and then found out the hubs were the problem. So they bought hubs, removed the shafts, and returned them.
Old Jul 17, 2008 | 03:27 AM
Pablo-UA's Avatar
Pablo-UA
Seems to me Cardone use some used parts making new parts...
Old Jul 17, 2008 | 06:54 AM
96_4wdr's Avatar
96_4wdr
i don't see any bolt head scratches on the inner mounts.
doesn't look like any grease was put in the inner CV back.
the boots are too clean for an install by any mechanics i know.
probably just opened, the repair person realized their problem was the hubs after dis assembly of the front drive
call RockAuto and see what they say.
are these the Cardone new manuf. or their rebuilds?
Old Jul 17, 2008 | 10:15 AM
Pablo-UA's Avatar
Pablo-UA
I think no reason to worry. Scratched surface toches no part of truck. Install and n'joy
Old Jul 17, 2008 | 03:47 PM
MisterCMK's Avatar
MisterCMK
AFAIK, Cardone doesn't make new parts, they re-manufacture them instead.
Old Jul 17, 2008 | 04:46 PM
amaviper's Avatar
amaviper
No those units where supposed to be brand new manufactured parts. It was their "select" line. I contacted Cardone and sent the same pictures. Cardone said that they are supposed to be NEW units and I should return the parts to Rockauto. There shouldn't be any grease present on the splines of the parts. It doesn't appear that the parts where fully installed. The inner mounts aren't scratched where the bolts would go.
When I buy new parts - I expect new parts !
Not one - but both of those units were sent out before and are "used". I have no doubt they were at least put into an axle assembly - both of them. Who knows - they could have been stressed from hanging or who knows what.
Not sure what I'm going to do yet. If I use them I will have to clean up the splines etc. I think they should give me a discount at the very least if I keep them...
I would post the message Cardone sent - but there is a confidentiality clause.
Is this normal for RockAuto?
Old Jul 17, 2008 | 06:16 PM
MisterCMK's Avatar
MisterCMK
I don't think it is normal. Send them back and be done with it.
Old Jul 17, 2008 | 09:44 PM
96_4wdr's Avatar
96_4wdr
Products
Leveraging over three decades of automobile parts remanufacturing experience,CARDONE Industries now offers a line of totally new manufactured parts, under the brand name CARDONE Select. By adding a "new" division to our existing remanufactured lines,we are able to reach a larger customer base and provide a wider variety of “blended” options for automotive parts replacement. Initial product offerings feature CV Drive Axles, Distributors, Intake Manifolds, Master Cylinders, MAF Sensors, Power Steering Pumps, Vacuum Pumps, Water Pumps, Window Lift Motors, Wiper Motors, Wiper Motor Pulse Boards, Starters and Alternators.
The same reverse-engineering expertise that has made A1 CARDONE synonymous with quality is what drives the techniques used in manufacturing CARDONE Select products. The combined knowledge and experience that resides in every CARDONE factory family member from engineering through production has allowed us to take an unprecedented approach into the “new” market. This inherent confidence is what sustains CARDONE as we aggressively expand our new product offerings to eventually match the breadth of coverage that currently exists in our remanufactured lines.
Old Jul 18, 2008 | 12:26 AM
xlt4wd90's Avatar
xlt4wd90
Who was it who wanted to use a Cardone steering rack as a weapon?
Old Jul 18, 2008 | 08:55 PM
MisterCMK's Avatar
MisterCMK
Originally Posted by 96_4wdr
Products
Hence my "as far as I know". Thanks for the info though, I never knew that they made new parts as well. I wonder if they suck as bad as the remans.
03silverTJ
May 12, 2016 01:34 AM
slimbo13
May 14, 2014 11:16 AM
jdecker88
Jun 21, 2010 10:24 PM
