New buyer
Old Oct 6, 2016 | 02:54 PM
Strech46290's Avatar
Strech46290
New buyer
He guys and gals!
New member and new buyer of a dentside.
Little information about what I'm looking for. I want a 4*4 to get though the snow when my 2wd 03f150 won't handle. I do a small snow removal route and drive when the roads are not cleared yet. I also will not be plowing as this truck is for me only for the sidewalk route. This truck is for Chicago city driving and snow only.
I have found this and spoke with the guy. I feel it is overpriced but would like your opinions.
https://chicago.craigslist.org/sox/cto/5773483236.html
Guy says rear gear is 3.80 Detroit locker. Is this possible?
Old Oct 6, 2016 | 09:16 PM
Strech46290
1979 f150 4x4
Old Oct 6, 2016 | 10:49 PM
PapaBearYuma's Avatar
PapaBearYuma
Originally Posted by Strech46290
I'm very suspect of things that don't match the pictures, and of relatively simple things left undone
The pictures show a "custom" dash, but the description says custom dash removed and cluster put back in. Does any of the replaced cluster work? Why not a picture?
The description also says it needs a wheel cylinder. That's an easy fix, so why hasn't he done it? Probably cuz there's more and bigger problems in the brakes
The truck has a Lund visor. Every Lund visor I've seen has been accompanied by a lot of rot, rust and cancer
The picture is vague, but the right rear looks rusted-out/repaired/primed. Something going on there. Theres a lot going on here, and it's probably bad news
Old Oct 6, 2016 | 10:57 PM
Strech46290
A few pictures he sent today.
Old Oct 6, 2016 | 11:13 PM
Strech46290
Yeah I agree seems like alot going on. I'll just have to keep looking. I'm sure I'll find one!
Old Oct 6, 2016 | 11:18 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Gobs of bondo and rust, looks like it has a suspension lift (radius arms drop brackets) and a body lift (front bumper gap). And a cobbled up dash with I am sure some accompanying wiring nightmares.
You are looking at a VERY VERY used truck. I would not pay that asking price. Have you read this? https://www.ford-trucks.com/forums/1...l#post14696861
2wd in snow... some sand bags, large tree stumps or stacked fire wood in the bed, some all terrain rear tires and use the slight application of the brake pedal to stop the one wheel rear spin.
Old Oct 6, 2016 | 11:32 PM
Strech46290
Yes I have been through a couple hundred pages in this section already before I signed up. I have seen your post a few times!
I have used the 2wd the last few years for this route. It works but a 4*4 will make things easier. Trying to break through some of the alleys here can get squirrely. It's the foot + storms I am having trouble with.
Old Oct 7, 2016 | 06:45 AM
77&79F250's Avatar
77&79F250
That buyers info is from compilation from a few FTE members. Nothing beats a 4wd when trying to get around reliably. And that is the biggest deal when shopping for a used 4wd truck, finding one that is reliable. or at least easily maintained in a DD status.
Sounds like a stock 4wd is what you might need or be better to look for? Cause remember a stock 4wd, especially with stock rims, tires and no lift might of had a better life than a already lifted big tire truck.
Worse case put some tire chains or "traction straps" on the back end of the 2wd.
Old Oct 7, 2016 | 11:33 PM
Strech46290
What do you guy think of this one.
It looks to be in better shape? Its a little further drive to check out then the first one.
1978 FORD F150 RANGER XLT 4x4 SOUTHERN TRUCK SHORT BED
Old Oct 7, 2016 | 11:49 PM
AK FORD GUY's Avatar
AK FORD GUY
I guess for $5k, I just expect more.
Looks like a decent truck, but I'd still be suspect of the "professional work". It doesn't look that well done to me, but it's hard yo tell in the pics.
Old Oct 8, 2016 | 12:03 AM
PapaBearYuma
The left bed and right door look pretty rough, also. A lot of rot for never seeing "winter salty roads". $5k seems kinds high...
Old Oct 8, 2016 | 12:21 AM
Strech46290
Thanks guys.
I'll keep looking.
What would you say is a fair price for that truck if 5k is to much?
Old Oct 8, 2016 | 01:20 AM
AK FORD GUY
Here's one:
1977 Ford F150 Ranger 4x4
Old Oct 8, 2016 | 06:45 PM
Strech46290
Thanks AK ford guy. I sent him a text and called no answer or reply yet.
I did find this one just now.
1978 Ford F250 cammper special 4x4
Old Oct 8, 2016 | 07:13 PM
AK FORD GUY
I almost posted that one last night too, but was too tired and the wifi signal at work was getting weak.
Depending on what you want and how much work you want to do, either could be decent rigs.
