Powder coating the smog pump
Old Oct 6, 2016 | 08:38 AM
gbakman's Avatar
gbakman
Has anyone powder coated a smog pump or disassembled it. I plan to have powder coated and can not get it apart. I get the case open but cannot get the guts out. Any tips or ideas? The place that powder coats states it gets to 400 degrees for 45 minutes. I am afraid that will melt the rubber fins inside the pump. Not worried about the metal getting damaged inside. Any tips would be appreciated. Thanks
Old Oct 6, 2016 | 08:03 PM
Franklin2's Avatar
Franklin2
Does this look like yours?
Engine - Smog Pump Self Repair! | Mustang Forums at StangNet
Old Oct 10, 2016 | 02:38 PM
gbakman's Avatar
gbakman
Yes that is the beast. I got it apart like your pictures but cannot get it gutted. I have a place that powder coats cheap and they will do it If I can gut it. Any suggestions?
Old Mar 8, 2017 | 01:36 PM
RangerMercMan's Avatar
RangerMercMan
Thank you resonateur for all the advice especially on the rear axle setup
Old Mar 9, 2017 | 08:52 AM
cadunkle's Avatar
cadunkle
If you're concerned about appearance, it'll look a lot better if you eliminate the smog pump and use early alternator brackets to get the chunky cast mounting part out of the way. Spend the money to get non smog pump headers and have them coated.
Old Mar 9, 2017 | 11:19 AM
Wagonboy's Avatar
Wagonboy
I am going to paint mine.
Helpful Link => Dissecting the E5TE-DB smog pump... - Ford Bronco Forum
Nick bass
Sep 18, 2012 11:00 AM
1994 F250: 351, C6
15
Feb 16, 2009 02:25 PM
jblueep
13
Jan 22, 2007 04:41 PM
silvers
May 12, 2004 02:14 PM
