1978 - 1996 Big Bronco
Inertia Switch
Old Aug 22, 2003 | 11:43 AM
Patrick8475's Avatar
Patrick8475
Inertia Switch
Hello
I was wondering if anyone could tell me where the inertia switch is located, and how you shut it off.
Thanks
Patrick
Old Aug 22, 2003 | 11:47 AM
jbalestri's Avatar
jbalestri
Inertia Switch
It should be on the firewall, behind the clutch/brake pedal assembly in the cab. There is a red plunger type switch. I do not remember if you push it down, or pop it up. It is protected by a black collar for safety. I think you push it down. To activate it, just take a small screwdriver and pop it up.
Old Aug 22, 2003 | 11:48 AM
frogger01's Avatar
frogger01
Inertia Switch
Depends on the year. I know in the Early-mid 80s it was located on the firewall on the passenger side and in 92-96 it was located in the passenger kick panel up at the top. As for 87-91 I dont know it's exact location.
Old Aug 22, 2003 | 04:30 PM
JBronco's Avatar
JBronco
Inertia Switch
What's an inertia switch? I never knew I had one. I'm guessing that this is something to turn the fuel pump off or something if the truck tips over?
Old Aug 22, 2003 | 04:43 PM
jbalestri's Avatar
jbalestri
Inertia Switch
It is on fuel injected vehicles. It kills the power to the fuel pumps when the vehicle encounters a hard enough bump. It's a great way to shut the pumps off to relieve the system of pressure for fuel filter changes, etc.
Non-fuel injected do not have a inertia switch.
Old Aug 23, 2003 | 02:55 PM
steve83's Avatar
steve83
Inertia Switch
Any vehicle with an electric fuel pump SHOULD have an inertia switch. It keeps the pump from flooding the engine bay with gas if a fuel line ruptures in a collision. Some carb vehicles use an electric fuel pump, so they have an inertia switch.
Old Aug 26, 2003 | 06:20 PM
frogger01's Avatar
frogger01
Inertia Switch
Steve's right my old CC Dually which was carbed had an inertia switch for the fuel pumps.
Old Aug 27, 2003 | 08:19 AM
jbalestri's Avatar
jbalestri
Inertia Switch
Brain flatulance on my part. I've either had old vehicles with mechanical pumps or FI.
VannerDude
Feb 22, 2015 01:54 PM
gman97005
Dec 12, 2014 06:32 AM
Justin Jude Solet
Mar 11, 2014 12:04 AM
w craker
Apr 19, 2013 08:35 AM
dayday
1997 - 2003 F150
Nov 16, 2010 05:39 PM
