interior light questions
Old Oct 3, 2016 | 06:49 PM
hurst1979olds's Avatar
hurst1979olds
Well. I've been putting some miles on my truck and absolutely loving it. I've been getting the kinks out of it. The recent one was the dash lights didn't work. So I pulled the cluster out and I was missing some of the twist lock bulbs. Which would explain it. So I bout a 10 pack and changed them all.
I got it back together and now my dome light won't turn off. Its stays on constant. Other then the door switches, what should I be looking at. It wasn't like this before I took the dash apart to pull the cluster so that's why I'm thinking it's something from under there.
Old Oct 3, 2016 | 06:55 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Turn the light switch ****.
Old Oct 3, 2016 | 07:59 PM
hurst1979olds
Oh jeez. I hope it's that easy. But I feel dumb for asking and not thinking of that.....should have put the beer down earlier.
Old Oct 3, 2016 | 09:38 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Beer or no beer, everybody has DOHH! moments every now and then.
Hope that's it.
Old Oct 19, 2016 | 06:08 PM
hurst1979olds
Well. Now I got no tail lights. Looks like I'll be tracing wires this weekend.
Old Oct 19, 2016 | 06:29 PM
mikeo0o0o0's Avatar
mikeo0o0o0
With these trucks, if it's not one thing, it's always something else.
Old Oct 21, 2016 | 12:14 PM
tlrtucker's Avatar
tlrtucker
I had the same exact problem after a motor swap - no turn signals, no running lights, no interior lights, but had brake lights.
Did some digging and found that the power wire coming from the ignition switch was literally blistering hot to the touch with the key on. Dug some more and found that my dad had spliced the power for the CB into the power wire for the ignition switch. Not sure if there wasn't enough of a ground, but once I disconnected it all of my lights started working. Haven't dug any more into it, but I'm seriously considering completely re-wiring the truck. It's 40 years old and I'm sure there are more gremlins in there somewhere...
Old Oct 21, 2016 | 01:23 PM
hurst1979olds
I did the "wiggle" test under the dash. Since I was working under it I thought maybe it was something under there. Ive read to the check the harness where the front and back meet. Also I have a trailer plugs, Ill look to see if something if fishy with that even.
My plans is to rewire the whole truck one day. Ill need an engine in a couple years, probably then.
Old Oct 21, 2016 | 02:08 PM
tlrtucker's Avatar
tlrtucker
I suggest doing a quick check of all power and ground wires. Doesn't take long and could flush out your issue.
As for the interior dome light, I wouldn't even really mess with testing the door jamb switches. I ordered 2 from LMC for about $7/each and they took 10 minutes to install. Fixed my no-dome-light issue.
Old Oct 21, 2016 | 02:16 PM
meangreen92's Avatar
meangreen92
And make sure you have a ground strap or cable between your block and the firewall/cab.
Old Oct 21, 2016 | 03:50 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
If rotating the head light switch turned the dome light off, but now your tail lights are gone, it might be a bad head light switch?
Old Oct 25, 2016 | 06:16 PM
hurst1979olds
I got the interior light problem fixed. But I lost the taillights. The brake lights still work as they should. I changed the headlight switch and that didn't fix it. I did a wiggle test on the whole Harness going back to the tailights and that's all good. I found by the back shock mount some boogered up section that had a bunch of electrical tape. I'm going to look into that and I'll bypass the "T" for the trailer harness to see if that does it as well.
Old Oct 25, 2016 | 07:23 PM
daltonjamesadams's Avatar
daltonjamesadams
My tail lights were intermittent, there is a brown plug drivers side near firewall with 1 wire from cab going to 2 going to back of truck. Took it apart and cleaned it, taught my 15 year old about test lights and current while doing it, fixed it.
Old Oct 25, 2016 | 08:19 PM
duste's Avatar
duste
Is it just the taillight at the rear or are all the park lights out? If they are all out check the fuse, if that's good and you had all your lights before you pulled the dash I would be learning at the switch. Try removing the **** again and reinstalling it .I did have 2 switches go bad on me over the years.
Old Oct 26, 2016 | 08:36 PM
hurst1979olds
It's just the parking lights. Brake lights still work. It did happened after I pulled the dash. I thought switch too so I changed it and it didn't fix it. I'll try pulling the **** again.
rchawaii
Jun 27, 2019 12:17 AM
FordBoy2012
Jan 16, 2016 10:52 PM
MyName1sMud
20
Jan 15, 2015 01:56 PM
ihateminimumwage
23
Jul 20, 2011 07:38 AM
GeneStoner
Jan 15, 2005 02:00 AM
