Not on a regular basis! 1987 F250 6.9L, original owner. Years ago I had the air cleaner off to clean it up and repaint it. I had to make a short drive, 1/2 mile or so and saw oil dripping from front of engine. My friend/mechanic said running without the air filter caused high crankcase pressure. True or false?
You can get away with a lot. Obviously, no filter = better chance of sucking something in that will score the cylinder walls and damage something.
Crank case pressure, no. Just no.
Two things:
1. The seals on this engine are spring-loaded teflon or rubber slip seals. They face outward in such a way that pressure in the crank case forces the seal more against the spinning crank, increasing the amount of 'sealing power' at higher levels of crankcase pressure.
2. The IDI has a "crankcase depressurization regulator" which effectively regulates crankcase pressure. It's supposed to basically keep the pressure at atmospheric, but at high RPMs, prevents the engine from /sucking/ the blowby in and creating a negative pressure in the crankcase.
