Disconnected fuel selector switch, any problems?
Old Oct 3, 2016 | 01:30 AM
EDsurvivor's Avatar
EDsurvivor
1988 F250 XLT Lariet, 460, EFI, 4x4, C6, reg cab, long bed
I'm embarrassed to ask this but oh well. If I remove the fuel selector switch, the one in the dash to the left of the steering column, will this cause a problem with fuel delivery to the engine? Does this somehow disable anything?
Old Oct 3, 2016 | 10:15 AM
mrollings53's Avatar
mrollings53
Yeah, your fuel pumps won't turn on. It needs to be wired so one of the tanks is always "selected".
Old Oct 3, 2016 | 10:26 AM
BLDTruth's Avatar
BLDTruth
Yup as said above it will disable your truck from running.
Old Oct 3, 2016 | 10:31 AM
EDsurvivor's Avatar
EDsurvivor
Okay, that's a relief. Thanks for the replies.
Old Oct 3, 2016 | 11:42 AM
rla2005's Avatar
rla2005
You also need to connect the fuel level sensor to the dash gauge. That signal also goes through the fuel tank selector switch.
Old Oct 4, 2016 | 04:59 AM
My4Fordtrucks's Avatar
My4Fordtrucks
That's sort of an odd question. Why do you want to remove the switch?
Old Oct 4, 2016 | 09:54 AM
EDsurvivor's Avatar
EDsurvivor
I don't want to remove the switch permanently. But I had temporarily removed the switch along with the rest of the trim around the instrument cluster. The truck was sitting like this with the dash apart for a while.
Then I took the truck for a test drive for something unrelated to the dash. Never gave any thought to the condition of the dash. The truck started and I got about 1/2 down the road where it sputtered and died. My wife helped me tow it home.
I was scratching my head over this, came to the conclusion that it might be that fuel selector switch. Installed the switch and was back in business.
I was asking the forum about this just out of paranoia, just to make sure it was just that simple, and that I wasn't over looking something else.
edlingler
15
Feb 7, 2013 09:12 PM
BigJake34452
Jul 4, 2008 09:49 AM
adrianlovessnow
Jan 9, 2008 04:35 PM
highrisk
Feb 12, 2007 03:51 PM
CARLOCO
May 13, 2005 03:01 PM
