fuel system trouble
Old Dec 14, 2012 | 05:24 PM
edlingler's Avatar
edlingler
fuel system trouble
i have a 1992 f150.i parked the truck for about 15 min. and when i tried to start it the pumps wouldn't work in the on position. tracked it down to the selector switch and replaced.now the pumps will hum in the on position but aren't pumping the lines up. any suggestions? i should add that both pumps were working before this happened.
Old Dec 14, 2012 | 05:48 PM
Puddy's Avatar
Puddy
Under the dash there is a fuel kill, see if it tripped
Old Dec 14, 2012 | 05:56 PM
edlingler's Avatar
edlingler
thanks Puddy, but i came thru the inertia switch on my way thru to the tank selector switch
Old Dec 15, 2012 | 10:31 AM
rla2005's Avatar
rla2005
The only thing between both fuel pumps and the fuel rail is the fuel filter. Have you replaced it or removed the line running to it then checked for fuel?
There is a test port on the fuel rail so you can check the fuel pressure with a gauge.
Old Dec 15, 2012 | 06:16 PM
edlingler's Avatar
edlingler
don't understand how two pumps take a dump at one time but today i jumped the pump off of the battery after pulling the lines off the pump. it hummed and hummed but no gas . guess i'll try a new pump.
Old Dec 17, 2012 | 11:39 AM
edlingler's Avatar
edlingler
o.k. I've replaced one relayand swapped the other with the horn relay. I've checked theshut off switch and replaced fuel selector switch. I've also changed the inline filter. traced electric back to the pumps.with the key on I've 12v at the pump and the pump would hum but not pump fuel. I got mad and threw a new pump at it....same thing. any ideas ? help, please! I keep thinking about fixin' it with a 12ga.
Old Dec 17, 2012 | 02:10 PM
rla2005's Avatar
rla2005
From Post# 4: "Have you replaced it (fuel filter) or removed the line running to it then checked for fuel?" I see you replaced the filter, did you pull the line leading to the fuel filter then check for fuel? Jumper pins 2 & 6 on the Diagnostic port, then turn the key on. This will keep the pump running all the time. Much easier to diagnose the problem.
Old Dec 18, 2012 | 11:44 AM
Truckin Bob's Avatar
Truckin Bob
Just for grins.........
When you turn the key to "on" (not start) does the fuel pump run/prime for 1-2 seconds then shut off or do they run continiously ????
Just lookin' for a little piece of the puzzle that may be missing.......
Bob
Old Dec 18, 2012 | 12:51 PM
edlingler's Avatar
edlingler
Bob
at first it wouldn't then I replaced the selector switch.now the pump will run for a couple secs.and shut off but not pump any fuel
Old Dec 18, 2012 | 05:39 PM
rla2005's Avatar
rla2005
So this leads us back to what I asked in posts 4&7.....
Old Dec 19, 2012 | 12:32 AM
edlingler's Avatar
edlingler
yes,sir, I've pulled the lines off at the pump and filter.figured i'd follow it on up to the motor.even pulled line off at pump and wired it from battery, ran pump aprox. 1 min. no fuel. thank you,Ed
Old Dec 19, 2012 | 07:09 AM
subford's Avatar
subford
Sounds like you missed wired the selector switch. I think you are sending gauge power to the pump and a full 12 to the gauge sender.
If not that you have lost the ground at the radiator drivers side.
Old Dec 30, 2012 | 10:01 AM
edlingler's Avatar
edlingler
found it! valve between sending unit and fuel line was stuck shut.i'll remember that one!
Old Dec 30, 2012 | 10:32 AM
subford's Avatar
subford
Glad you found it and got it fixed.
Hope you do not have a cross flow problem now.
First time I have heard of that recall pressure line check valve sticking closed. I hope you took it off and pitched it. They were meant for the 1993 trucks that had the bad fuel pressure regulators and someone put it on your 1992. That was a cheap fix for the blown out check valves in the 1993 trucks FDM as Ford did not want to replace all of the FDM's on the 1993 trucks that had the bad pressure regulators.
Old Dec 30, 2012 | 11:19 AM
rla2005's Avatar
rla2005
X2...thanks for the feedback. I overlooked that check valve as well. Never heard of one going bad in that fashion.
