Oil pressure guage setup?
Old Aug 22, 2003 | 08:21 AM
superrangerman2002's Avatar
superrangerman2002
Question Oil pressure guage setup?
I was wondering if anyone had some luck on changing their stock oil pressure setup (it's just a dummy gauge), to a real time reader, on any newer models of rangers?
This spring I had the back of my speedo out all ready to do the conversion, but I couldn't find any thing close to the resistor that needed to be jumpered.
So I pretty much gave up on it, then I had heard some rumors that all you need to do is change out the oil pressure switch with a oil sending unit, and bam, you have a real time unit.
Does any one know if there is any truth to this? If so, what type of sending unit will I need?
Old Aug 22, 2003 | 06:35 PM
Ken00's Avatar
Ken00
Get with Bob Ayers on this, he did it with his 1999. I believe he did a post on this topic.
Old Aug 22, 2003 | 08:09 PM
Bob Ayers's Avatar
Bob Ayers
Yes, I converted my 1999 3.0L FFV. I did the same thing, pulled
the instrument panel, and never did find the 20 OHM resistor
that is supposed to be in series with the gauge, and the sending
unit "SWITCH". So, all I ended up doing is changing out the
"SWITCH" with an analog oil pressure sending unit. Since the
analog sending unit is a lot bigger than the "SWITCH, you may
need a 90 degree coupling with your 4.0L.....Good luck!!
Old Aug 23, 2003 | 09:42 PM
DMW's Avatar
DMW
Anyone know what model/year of car to specify to get the correct sending unit? I believe oil press (and water temp)gauges need to be 'matched' to the sending unit in terms of the proper voltage range specification. ??
Old Aug 25, 2003 | 09:05 AM
superrangerman2002
Sorry for the late reply.
hey thanks guys, I had a sneaking suspicion that all I would need to do is change out the sending unit.
As far as which unit to use, i'm sure that the 3.0l ranger and the 4.0l ranger would be able to use the same analog sending unit.
I think that i'll give it a whirl and post my results.
Old Mar 12, 2005 | 05:57 PM
soksniffer's Avatar
soksniffer
I'm not sure if this is Bob Ayer's truck (it belongs to a Bob but I didn't see a last name anywhere), but this fellow did a conversion on his '03 FX4 LII. I'd like to try it, too, but judging from some of his other work he's an electrical whiz (his radio volume changes based on his vehicle speed!!), and I'm definitely not--I still thrill at sticking my tongue on 9-volt batteries. Anyway, it can be done!
http://www.cardomain.com/memberpage/727284/3
Old Mar 12, 2005 | 07:40 PM
Ken00's Avatar
Ken00
FYI, it's not Bob Ayers truck.
Old Mar 13, 2005 | 08:06 AM
Bob Ayers's Avatar
Bob Ayers
Ken is correct, not my truck...Mine is a 1999 3.0L FFV...
Old Mar 14, 2005 | 10:25 AM
pawpaw's Avatar
pawpaw
Hey Bob Ayers, do you happen to remember the P/N & manufacturer of the analog oil pressure sending unit you used in this conversion????
Old Mar 15, 2005 | 03:09 PM
goodbread's Avatar
goodbread
Bob,
What sending unit did you use? I tried the same thing on my 99 3.0 FFV and failed?
Old Mar 16, 2005 | 06:40 AM
Bob Ayers's Avatar
Bob Ayers
Originally Posted by goodbread
Bob,
I don't remember the P/N, I do remember buying it at NAPA, and it was a lot bigger than the oil pressure switch.
Old Mar 16, 2005 | 07:00 PM
Ken00's Avatar
Ken00
Bob, do you remember what you asked for when you went to NAPA?
Old Mar 17, 2005 | 08:22 PM
Ken00's Avatar
Ken00
Thanks Bob.
Old Mar 17, 2005 | 11:43 PM
el conquistador's Avatar
el conquistador
advance auto has a GP Sorensen OPS71
Leroy Unlisted
Apr 5, 2016 07:32 AM
88n94
Oct 24, 2015 04:05 PM
Death_Eagle_571
Jul 4, 2015 02:15 PM
Mr-Pipeline
Modular V10 (6.8l)
30
May 17, 2010 10:13 PM
AggiePSD
13
Jul 28, 2002 05:45 PM
