Sponsored by: Real Truck
Intake manifold
Old Oct 1, 2016 | 07:16 PM
Borgia's Avatar
Borgia
Intake manifold
I was replacing my spark plugs and one screw holding the ignition coil stripped while another snapped. I have change 3 plugs (the easy one) and could have more problems. I spent half a day trying to drill the screws out to no avail and also noticed the intake manifold is plastic. I was thinking of swapping it out. This would alleviate the broken screw problem and make pulling the plugs easier. It also looks like it's just 8 bolts. Would swapping a new intake manifold in add any performance gains? Is there a manifold others recommend?
Old Oct 2, 2016 | 10:15 PM
fordmerc's Avatar
fordmerc
Let's start by letting us know what truck you are working on? Year, engine, mileage etc?
Old Oct 2, 2016 | 10:36 PM
dkf's Avatar
dkf
Those plastic intake manifolds can be prone to cracking, mainly around where the coolant passages are. It won't hurt to replace it and install new gaskets. Would also be a good time to clean/replace the IAC, clean the throttle body, inspect all hoses, etc.
Here is a write up.
2004 F250 Intake Manifold Replacement
Old Oct 3, 2016 | 08:27 AM
Borgia's Avatar
Borgia
02 f250 5.4
Old Oct 3, 2016 | 08:35 AM
The Bone's Avatar
The Bone
You may not be able to replace the intake with a metal one. However to avoid having the problem with the coil screws again use anti-seize on the threads on the screws
Old Oct 3, 2016 | 02:24 PM
Coronado's Avatar
Coronado
If it's anything like changing it on the F150, pretty dang easy. Parts weren't even that expensive if I remember right.
Old Oct 3, 2016 | 03:02 PM
wizkid00104's Avatar
wizkid00104
Jason did a really nice writeup on the replacement.
https://www.google.com/url?sa=t&rct=...aLpOa9Ysp3Qm9w
Old Oct 3, 2016 | 08:12 PM
Borgia's Avatar
Borgia
Yea that write up is great. Anyways I started the project and fairly easily got to the point where I'm ready to unbolt the manifold. Unfortunately the bolts are very rusty and I'm not sure I'll be able to get them out. Since the manifold is plastic I was thing of taking a saws all and cutting it out as much as I can and than when it's out I'll have more room to get a wrench on the bolts. Does anyone see any potential problem if I do this?
Old Oct 3, 2016 | 08:40 PM
dkf's Avatar
dkf
Center punch the center of the bolt heads and take a drill and drill them out until the heads pop off. A 1/4" drill will probably be large enough. Remember there are fuel rails nearby full of gas.
Old Oct 3, 2016 | 08:53 PM
Borgia's Avatar
Borgia
Problem is the more rusty ones are toward the rear and I don't see getting a drill in there. Maybe a pry bar or hammer to get it out? However the saws all shouldn't spark since it's cutting plastic right?
Old Oct 3, 2016 | 09:25 PM
dkf's Avatar
dkf
Don't want plastic dropping down the intake ports when you cut it. There are just brass inserts set in the plastic that the COP bolts screw into.
Old Oct 4, 2016 | 06:25 AM
wizkid00104
I would go nice and slow. Soak them with penetrating oil. Then try to break them loose. Once broken loose, soak in oil again and let them sit. Then slowly back them out. If they are galded up really bad, back them out a quarter turn and then crank them back in a quarter turn. Then back them out a half turn. This motions has gotten most fasteners out for me. When initially trying to break them loose, you can also try to snug them up to break the rust.
Old Oct 4, 2016 | 11:37 AM
Borgia's Avatar
Borgia
I was able to remove it. I used the 3/8 instead of the metric and it got a grip on them. I was able to get all but one out this way. The one that stuck was the last one in the corner, so I lifted up on the manifold and the plastic snapped around the bolt. I was than able to get a lisle bolt remove on it and it came out. The metal on the fuel injectors is pretty rusty. Do I need to replace these? I looked online and they seem pretty expensive
windgust
13
Nov 28, 2016 09:34 AM
Borgia
1997 - 2003 F150
Oct 4, 2016 04:19 AM
cmazz811
Mar 26, 2014 07:46 PM
TXRusty
Modular V8 (4.6L, 5.4L)
Feb 14, 2008 08:21 PM
imlowr2
Jul 16, 2004 06:15 PM
