New instake manifold?
Old Nov 24, 2016 | 11:22 AM
windgust's Avatar
windgust
Hello everyone,
I think that my intake manifold gasket is leaking. I tested it with carb cleaner. This is a 2001 car with 200,000 miles on the clock and it is still on the original intake manifold. The question is: given that it is an old manifold is it worth replacing it for a new one now that I am doing the tear-down?
I understand these plastic manifolds just age and eventually crack. Am I correct?
Any suggestions will be appreciated.
Thanks
Old Nov 25, 2016 | 11:59 AM
Casper99's Avatar
Casper99
yes i have heard they crack and yea it's worth it to change it out if you got the money to do so.my luck id reuse it and have issues later down the road, get one with the aluminium cross over that's in the front.i bought my 99 5.4 and it has an all aluminium intake manifold
Old Nov 25, 2016 | 07:57 PM
windgust's Avatar
windgust
Interesting. 99s came with aluminum ones from the factory or was that an aftermarket upgrade?
Old Nov 26, 2016 | 12:07 AM
5.4T's Avatar
5.4T
factory, but you will have to relocate some coolant hoses. I just can't remember which one?
Old Nov 26, 2016 | 01:21 PM
Skauber's Avatar
Skauber
The 1st gen had aluminum on 4.6 at least, but perhaps plastic on the 5.4? I know in the 1st gen and "phase 1" '03 and '04 2nd gen they had plastic intakes with aluminum crossover, but not sure if perhaps earlier 1st gens had full aluminum intakes, or if that was only on the 4.6 or what. I do have a friend with a '99 4.6 Expy which I know has a full aluminum intake.
Anyway, what was common in the plastic ones with aluminum crossover was that it would crack where the aluminum crossover connected with the plastic intake. In the '05 they changed this, and made the aluminum crossover a separate part and the intake pure plastic, which has for the most part cured the cracking issue.
Old Nov 26, 2016 | 09:17 PM
Casper99's Avatar
Casper99
How would i be able to know for sure it's factory or aftermarket ? easy way ?looks factory to me and my heater hoses are towards the back of it. i don't remember seeing any towards the front while i was changing the alternator but DID see some black plastic box looking thing under neat the intake ???? there were flat black plastic/abs pieces broke off just laying down in there i dug em all out and threw away maybe a heat shield ??
Old Nov 27, 2016 | 10:22 AM
ExplorerTominCO's Avatar
ExplorerTominCO
As best as I can tell this is my factory intake. See the aluminum coolant crossover?
Here's where they fail. See the crack in the upper window:
This is the Dorman recommended replacement:
Old Nov 27, 2016 | 12:32 PM
Skauber's Avatar
Skauber
Yep, that's a typical failure point in these intakes. The newer ones on the 3v engine solved this issue by separating these two pieces.
Old Nov 27, 2016 | 03:30 PM
Casper99's Avatar
Casper99
So now it's got me curious if mine is stock or just upgraded or a different year of engine since i keep reading about the plastic intakes issues on 99's mine being aluminium mines Expo is a 99 sure it's nothing special
whats the black box looking thing under there ?? lower intake plastic but upper one aluminium seems weird if you ask me
Old Nov 27, 2016 | 07:59 PM
windgust's Avatar
windgust
Thanks for all the replies. I tried to find an all aluminum manifold to replace mine with but I could not find anything for the 5.4L. All the ones I found were plastic with aluminum crossover. I guess I have no other choice but to replace it with a new Dorman unit.
Once again. Thank you very much.
Old Nov 28, 2016 | 02:01 AM
Skauber's Avatar
Skauber
That plastic box underneath is the lower part of the intake plenum. In the early models the intake plenum was separate, so the intake consisted of two parts, the upper part and the lower part with a gasket between. In the 3v, this is now only one part.
Old Nov 28, 2016 | 07:28 AM
ExplorerTominCO
The lower plastic part was part of the upper part (i.e. Only a single piece) in my 2000 2V. Plastic top and bottom.
Old Nov 28, 2016 | 08:33 AM
Skauber's Avatar
Skauber
I think even if the upper and lower is plastic, you can still separate them. They do sell a gasket which fits between the upper and lower plenum, so that leads me to think it's two pieces. When buying a new intake, I think they sell the upper and lower as an assembly, not separately, so you rarely ever have to separate them. I guess the only times would be if you're gonna replace the gasket, or perhaps for cleaning purposes, though since they changed the design on the 3v to a one-piece design, I guess it wasn't really needed to have them as two pieces.
Old Nov 28, 2016 | 09:34 AM
alloro's Avatar
alloro
Nice pictures, have some rep points.
bill4x4
Mar 7, 2014 12:35 PM
dgoebelt
1997 - 2003 F150
Apr 13, 2013 09:57 AM
twall_SD250
Dec 29, 2010 11:26 AM
twall_SD250
Modular V8 (4.6L, 5.4L)
Dec 28, 2010 09:13 PM
imlowr2
Jul 16, 2004 06:15 PM
