Sponsored by: Real Truck
Front diff Removal
Old Sep 30, 2016 | 04:33 PM
Glenn.b1's Avatar
Glenn.b1
Front diff Removal
I have a '99 F250 Super Duty 6.8 V10 4 Wheel Drive. I am trying to replace the inner oil seals and need to remove the the diff. the book calls for a Diff housing spreader PT#205-001. Is this tool really necessary?? Where can I get One??
Thanks for your help in advance.
Old Sep 30, 2016 | 07:22 PM
senix's Avatar
senix
bump to the top. Not too many ever need to service the front diff. Hopefully someone chimes in.
Did you try to google it
Old Sep 30, 2016 | 09:15 PM
Glenn.b1's Avatar
Glenn.b1
Tried google, no help. Tried eBay and found 3 different ones. $130 to $170 bucks. I was able to pull it out with no problems and replace the seals with a piece of threaded rod and the right size washers. Also went back in fairly easily. so I guess if you are not replacing the bearings you don't need it.
Old Oct 1, 2016 | 08:23 PM
99f350sd's Avatar
99f350sd
Mine came out also without it...Good job on the seals. I did mine a while back..
Old Oct 1, 2016 | 11:28 PM
Glenn.b1's Avatar
Glenn.b1
Have put off the job for 6 months because of all the work to replace just 1 seal. Replaced both seals & all the vacuum seals in the hubs as well. They needed it.
Old Oct 2, 2016 | 06:50 AM
senix's Avatar
senix
Glad you got it. I would have thought that any real work on the front diff is rare, other than fluid.
Maybe not so rare after all.
Old Oct 2, 2016 | 07:22 AM
Tom's Avatar
Tom
I think it's rare for bearing issues because of how rarely the front axle gets used in most cases. Seals fail with age, though, and I suspect we'll be seeing more of these as time goes on.
Old Oct 2, 2016 | 09:37 AM
Glenn.b1's Avatar
Glenn.b1
I had the axle out a couple of times trying to fix the vacuum seals and probably damaged the seal. It's a '99 with 93K and sat for 4 or 5 years. I am surprised there aren't more oil leaks.
timm525
1997 - 2003 F150
Sep 27, 2014 03:46 PM
Johnnyboy1979
1997 - 2003 F150
Feb 4, 2008 06:48 PM
ford9991
Jul 5, 2007 07:26 PM
TexasGuy001
Feb 5, 2006 11:09 AM
SafetyBob507
Jun 29, 2003 09:18 AM
