Sponsored by: Auxito
Wheel bearings
Old Feb 4, 2008 | 03:30 PM
Johnnyboy1979's Avatar
Johnnyboy1979
Wheel bearings
I got a 1997 f150 with a 3:55 limited slip differential. I was wondering how hard of a job it is to pull the axles and change the wheel bearings and seals on this rearend. Thanks
Old Feb 4, 2008 | 06:48 PM
yankee7985's Avatar
yankee7985
Not real bad if you are mechanically inclined. First thing to do is jack up the truck and remove the tires and gain access to the end of the axles. Next, remove the cover from the rear end so you can drain the fluid and remove the pin and clips that holds the axles in place. Once this is done, remove the axles and remove the seals. They have a shoulder on them that goes over the end of the axle housing so it is hard to see with all the crud caked on them. Once you replace them, reassemble the items and refill the pumpkin. Don't forget to add the friction modifier.
ItsAFord55
Nov 20, 2015 02:24 PM
paker
1997 - 2003 F150
Feb 19, 2011 01:15 PM
Toyman
Aug 20, 2008 03:41 PM
beatle
Nov 19, 2006 10:47 AM
