Guage Cluster Question
Old Sep 29, 2016 | 01:40 PM
jackfordsd350's Avatar
jackfordsd350
Question. When first driving my truck in drive auto mode, the vertical 1 thru 6 transmission indicator next to the tach was on and reading what gear the truck was in. The last time I drove the truck the indicator was off and would only appear when I was in manual mode. There is nothing in the book regarding this and a call to was of no help either.
The members with trucks are my only way to to find out when this item is on. As far as I can figure, there is no way to control this.
Is your vertical transmission indicator in the tach cluster on all the time, Or just when the truck is in M mode.
Thanks,
Old Sep 29, 2016 | 01:50 PM
Chadmokc's Avatar
Chadmokc
Thanks,
When you are in Auto Mode just push up on the +- button on the gear shift lever and they should reappear. Try it and report back, because that's how it's done on my 2011. Just in case you didn't know, when in Auto, pressing down once the numbers are visible are how you lock out any desired gears you want and pressing back up will bring those gears back into play.
Old Sep 29, 2016 | 02:02 PM
jackfordsd350
Thanks for the quick reply. Just tried your suggestion and all is now working fine. I am coming off a 2000 F350 and trying to learn ASAP. The gear lockout info was explained in the book but not the info you supplied on turning on the readout. I don't know where we would get info without this site.
Thanks, Jack
Old Sep 29, 2016 | 02:03 PM
EightySecond's Avatar
EightySecond
Someone posted this question in the 6.7 Facebook group and someone else replied that you need to press the up button on the gear shifter to make it come back. That appeared to fix it, I have not validated anything.
Edit: Ok I see I am slow to the party. :-)
Old Sep 29, 2016 | 02:11 PM
EpicCowlick's Avatar
EpicCowlick
Good effort though Andy!
Old Sep 29, 2016 | 02:13 PM
EightySecond
E for effort. lol
Old Sep 29, 2016 | 07:06 PM
johndeerefarmer's Avatar
johndeerefarmer
On one of my previous 13 ecoboost they reflashed the truck and the gears were always there. On my 15 SD and 16 F150 they disappear as you said.
Old Sep 29, 2016 | 08:19 PM
archerseven's Avatar
archerseven
Yeah I'd noticed that, too. I caught on to it during my test drive, I like to tinker with things... if you hit up when no gears are locked out it'll toggle the display, and on my XL it saves it between restarts. I thought that was rather clever.
Old Sep 29, 2016 | 10:08 PM
Kenv's Avatar
Kenv
Yes...Chad is correct...BUT...there is also a way to set it to come on every time when you are in Drive also...my 2011 had that feature. When you start the truck it will be listed without having to press the + or -.......
Old Sep 29, 2016 | 10:25 PM
Chadmokc's Avatar
Chadmokc
Yeah I was just explaining how to get it to display. You don't have to set anything. Once it is displayed, it will show up every time he starts his truck and stay there. He has to manually push up on the +- button again to make it disappear. Same as my 2011.
Old Sep 29, 2016 | 10:48 PM
Kenv's Avatar
Kenv
Yep...I think that's what I was trying to say...lol. Thanks Chad.
Old Sep 30, 2016 | 09:58 AM
Rasty1's Avatar
Rasty1
Another great little tip from this forum! Thanks!
JlaneAK
Mar 26, 2017 06:54 PM
reelnut
Nov 4, 2016 10:14 AM
Subsailor1127
6.7L Power Stroke Diesel
Mar 26, 2015 10:19 AM
Fireman81
2009 - 2014 F150
Apr 19, 2012 02:03 PM
rclaye350
Apr 11, 2011 09:15 PM
