56 Panel not starting
Old Sep 29, 2016 | 05:18 PM
raytasch's Avatar
raytasch
Believe Nothing
Do not be that concern about the vacuum hose disconnected. Do be concern about plug wires routing and firing order and then distributor timing. May not be a bad idea to remove all the plugs and see if the engine will crank more rapidly, as suggested. Do you have any kind of a manual? If, not, research timing and firing order for the Cleveland 351.
Old Sep 29, 2016 | 05:57 PM
Kurt G.'s Avatar
Kurt G.
I believe this is the order, make sure motor is at #1 fire
Coachkev70's Avatar
Coachkev70
@JimG1098 - yes it is slow and labored. It's a new battery but have been trying to start for sometime. Have it on the charger now to ensure that the battery is fully strength.
@KurtG - Battery cables and starter cables have been replaced. As well as the starter is new too. The timing I am referring to is the distributor timing. When I got the truck the distributor was lose and was told the points were bad. I have replaced the points (dual points) and just had a call with the seller who pointed out that the vacuum advanced inside the distributor cap had come disconnected.
Kevin
Old Sep 30, 2016 | 01:48 PM
89gtstang's Avatar
89gtstang
Welcome to the site! I'm curious as to what the problem is.
Note this is just my input:
If before you try the pulling of all the plugs, to make sure that distributor is generally in the right spot you can pull the #1 plug find something to insert into the plug hole and turn the engine by hand until the #1 cylinder pushes that something up and than starts to go back down (there is actually a tool for this but why spend the $). This should be close to top dead center or 180 degrees out. IF there are timing marks on the crank you can see where that gets you on there or pull the cap and verify where the rotor is pointing to. Should be close to TDC on the crank or very close -just past- the #1 plug terminal on the cap or if 180 out, the #6 plug terminal. If I remember stock timing is 10 degrees BTDC on the 302 and 351W, but don't quote me on it with the Cleveland. If it's off set the crank to 10 degrees BTDC and/or turn the distributor to get it close and try again (note the distributor turns counter clockwise!, just have to say it as that got me once....once ).
With all that said.. with the low voltage to the coil timing may not be the issue but if you get that set right you can then rule it out. Good Luck and keep us updated!
Old Sep 30, 2016 | 01:49 PM
Coachkev70's Avatar
Coachkev70
Ok guys I have removed all the plugs and it didn't change the slow / laboring turning over. Just to be on the safe side I went and got a new battery as well and still slow / laboring turning over as if the battery was dead.
I am still concerned that I am not getting 12 volts at the starter which I believe would be the slow / laboring turning over. This doesn't make sense I have checked the grounds and they look and read good motor frame body. I even jumped the solenoid and still don't get 12 volts.
I feel eventually I will need to do a complete re-wire because the guy before did a Frankenstein job. I would like to get it running first. When I am ready to replace the wire harness is there 1 that you would recommend?
Old Sep 30, 2016 | 01:57 PM
raytasch's Avatar
raytasch
Believe Nothing
How about some detailed pictures of the wiring, starter, the solenoid that you jumpered. You do have a meter, do you not?
Old Sep 30, 2016 | 02:01 PM
raytasch's Avatar
raytasch
Believe Nothing
What transmission are you running?
Old Sep 30, 2016 | 02:56 PM
Coachkev70's Avatar
Coachkev70
I don't know the transmission...
Yes I have a meter.. I just checked again the voltage at the starter when attempting to start bounces around between 7-9 volts.
Old Sep 30, 2016 | 03:15 PM
raytasch's Avatar
raytasch
Believe Nothing
If you have a stick shift, is there any chance the flywheel cover or dust cover could be jammed in against the flywheel? Or is there a chance rodents could have found their way into the clutch or into the torque converter area?
Not sure I visualize where those extra wires are going or their purpose.
Old Sep 30, 2016 | 03:47 PM
SumDayDryvr's Avatar
SumDayDryvr
Welcome to the site. You seem to have replaced everything, so the next step would be to follow the power from the battery. The solenoid(sp?) is the gap between the battery and the starter. Are there 12 volts crossing it or is it bad. Only a guess as electrical issues can be very frustrating. Good luck.
Old Sep 30, 2016 | 04:02 PM
Coachkev70's Avatar
Coachkev70
it's an automatic.. Funny you mention rodents no there are no rodents actually had a rodent inspection today (wife heard noise in attic) ..
I assume the extra wires you are referring to is on the solenoid? well the I know the big cables on either side, left goes to positive on the battery and right goes to starter.. the 2 middle posts not sure but thought they go to the ignition. Left middle is labeled (S) and when the key is in the start position voltage bounces around between 6 - 8 the middle right post labeled (I) gets voltage when key is in the on position and I get 5.6 volts steady.
Old Oct 1, 2016 | 12:45 PM
Kurt G.'s Avatar
Kurt G.
Hey Kevin, just for fun you should pull the starter on test it to see how it spins when free. looks like it's easy to get to and a set of jumper cables would work for power. I've found bad starters like that. If the thing doesn't try to jump away from you when laying on the ground then that starter needs further testing like at a place that can read the amp draw.
Old Oct 1, 2016 | 12:59 PM
  #28
JimG1098's Avatar
JimG1098
answer to your wiring harness question. I put a EZ-21 in my truck. Pulled every bit of old wiring out of truck and totally rewired. Worked out well .
Did you personally ever see this truck run? This is an automatic or stick?.
Old Oct 2, 2016 | 02:06 PM
  #29
Coachkev70's Avatar
Coachkev70
I like the idea of pulling the starter to test. I will try todo that this week.
Prior to buying the truck the guy sent me a video of it running also when I received the truck I was able to briefly get it started running really rough and couldn't keep it running. The guy I bought it from said that the points where bad so that is why I assumed it wasn't running. I have since changed the point but even prior to changing the points I couldn't get it to start again.
I did just speak to the seller and he mentioned he had the same problem but it was because the vacuum advance came disconnected within the distributor. I checked it was disconnected I have reconnected but no difference nor do I think this would be the cause of the low voltage at the starter.
Old Oct 2, 2016 | 02:37 PM
  #30
Tedster9's Avatar
Tedster9
Don't worry about vacuum advance right now. You need a big fat blue spark at the plugs that snaps in the air.
Try replacing the condenser with a known good one, one made before this century.
dsnydly5
44
Jul 31, 2017 07:54 PM
Blackperry
43
Apr 11, 2013 09:55 PM
pburress
Electrical Systems/Wiring
Nov 27, 2012 02:43 PM
1949 F6
Jul 19, 2011 10:52 AM
a BigR HamR
May 28, 2008 04:47 PM
