What battery to use?
on
The starter will probably be okay.
on
I'm just guessing but I'd say it has probably been already been converted to 12V, but it is possible that some 6V items are still being used. Perhaps, whoever did the conversion didn't do the job correctly. How much driving have you done with the 12V battery in it? Does the electrical system charge? Have you used the lights?
It is still a positive ground. What is the purpose of the regulator? The lights seemed to operate fine on the 12v battery, as well as the starter and fuel pump and the truck would seem to run smoothly. It just had the problems I already stated like the ignition (6V) getting hot and the regulator ticking. I hope I didnt blow $100 on a 6v battery I didnt need.
One thing to check is to see if you have voltage reducers at the back of the gauges. If the gauges are stock and running on 12v, then you should find some reducers.
FYI, 12V ignition should have a ballast resistor feeding the distributor. The resistor reduces the voltage to around +/-9 volts. Otherwise you will be blowing points all the time. Have you been?
shrekau
20
03-13-2014 09:30 AM
uknunn
19
11-29-2013 10:40 AM
Walle1danman
13
07-09-2013 11:02 PM
two4two
33
02-06-2012 09:29 PM
turnrjr
10-06-2009 07:11 PM
