oops(damn)!
Old Sep 27, 2016 | 10:28 PM
dazedandcofused's Avatar
dazedandcofused
oops(damn)!
my steering colum was messed up om my 69 camper special the privious owner took the nut off and tried to take the wheel off with a hammer and it messed up the threads and the turn signal switch so i went to pull and save to get a new to me colum with the shift linkage and all for 25 bucks. everything was there on the colum and i found the 6 pin connector but couldn't find the two pin connector and it was dirty inside so i decided to tinker(dumb), i put it all back together but there was a big gap so like an idiot i used the impact to try to lessen the gap and it almost worked until the nut went to far( i am talking about me and the steering wheel hold down nut.) i couldn't reverse the nut and the turn signals still don't self cancal then i tried to cut the nut off and chewed up the threads on the top end so now i have to go get another colum. what other years will fit? it has two connecters,one with 6 pins another with two pins. i would like to get a more modern one with cruise and dimmer up on the colom but that requires a lot of rewire but it would be nice.
Old Sep 28, 2016 | 04:40 PM
JEFFFAFA's Avatar
JEFFFAFA
1967 to early 1969. 1969's before ser number G30,001. 1975 was the 1st year for cruise control in pickups. 67/77 will all have the neutral safety switch on the bottom of the column. 1978 was the 1st year for tilt steering. 78/79 Dentside column has no provision for the neutral safety switch. Ford had moved it to the tranny.
Old Sep 28, 2016 | 08:31 PM
72CC428's Avatar
72CC428
Hey Jeff, this just got me to thinking... What about using the tilt wheel from 78/79 and putting the NSS in the dash as a " push button ".
Push Button w/ R hand and turn ign. key. Easy way to solve the NSS issue and a " Toothless Jake " theft proof device!
Old Sep 29, 2016 | 04:54 AM
jowilker's Avatar
jowilker
With steering columns, you need to have matching gears to connect to. While the total length is the same, the connect point is 2 1/3 in closer to the firewall with the later Saginaw gear.
For a fact, you do not have to use NSS, I drove my 66 for 15 years without one. It can be started with the gear selector in any position.
John
Old Sep 29, 2016 | 12:29 PM
JEFFFAFA's Avatar
JEFFFAFA
Yepper. That's why I mentioned the tilt. From "the other site" you can go here:
How to Install a Tilt Steering Column in a '67-'72 Ford Pickup
(under construction)
Old Sep 29, 2016 | 06:47 PM
Millam's Avatar
Millam
There used to be instructions for swapping in a caddy tilt column.
Old Jun 2, 2017 | 12:26 AM
dreamofford's Avatar
dreamofford
so something from 67 to 76? maybe i will find one with cruise to make it look different.
Old Jun 5, 2017 | 11:27 AM
TeachNlive4ever's Avatar
TeachNlive4ever
I've installed a few tilts in bumps over the years. The "gap" is not the wheel needing to be tightened down, but the column shaft needing to come up by the column shroud adjustment.
Old Jun 5, 2017 | 11:30 AM
dreamofford
yep found that out to late next i won't use an impact driver.
Old Jun 5, 2017 | 03:22 PM
ultraranger's Avatar
ultraranger
'67-'69 columns will have two separate connectors coming from the column to plug into the two connectors on the main wiring harness under the dash.
'70-'72 columns will have one connector coming off the column to plug into the main wiring harness.
'73-'79 columns will have one large semi-circular (gray) connector coming off the column. This connector isn't compatible with the main wiring harness connector(s) on the Bumpside main wiring harness but, it is possible to wire the TSS in, without cutting any of the Bumpside main wiring harness wires, by fashioning up a short patch cable to plug in in between the column connector and the main wiring harness connector(s).
The Bumpside through 1977 Dentside trucks with an automatic transmission had the NSS on top of the steering column, inside the cab, near the firewall. In '78, the NSS was removed from the steering column and was mounted on the left side of the automatic transmission.
Old Jun 5, 2017 | 08:41 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford: Speed (GM: Cruise) Control: 1975/77 F100/350.
Speed Control and/or Tilt Wheel: 1978/79 F100/350 & Bronco.
Speed Control/tilt wheel not available in F100/150/250 w/3 speed manual.
Old Jun 7, 2017 | 11:55 AM
dreamofford
yeah i know it is suppose to have two connectors but i cannot find the small connector.
Old Jun 7, 2017 | 01:01 PM
JEFFFAFA's Avatar
JEFFFAFA
PO prolly cut it off the wires. Look around for the correct color wires without a connector.
Trigger_76
Nov 14, 2016 06:45 PM
Sportsterengr
Jul 31, 2016 06:33 PM
Danny_Ocean
Jun 19, 2006 10:57 PM
460_Sprout
Jul 5, 2004 09:54 PM
Stephens
Jun 17, 2002 04:09 PM
