High Beam Indicator
Old Sep 26, 2016 | 09:41 AM
GreenMtnMan's Avatar
GreenMtnMan
High Beam Indicator
Mine was not working on the '72. Pulled the dash and found what appears to be the correct wire. How is it supposed to be attached to the bulb housing?
Old Sep 26, 2016 | 10:11 AM
351Cleveland C4's Avatar
351Cleveland C4
It doesn't. It attaches to the main plug and runs current through the printed circuit board.
Old Sep 26, 2016 | 10:24 AM
GreenMtnMan
Which would be where?
Old Sep 26, 2016 | 10:29 AM
351Cleveland C4
The large plug that you had to unplug to get that thing out....
Old Sep 26, 2016 | 10:55 AM
GreenMtnMan
O.K. Thanks. I don't see anywhere it would go into the main plug. One of the metal contacts must be missing. Come to think of it, when I pulled the dash out, that wire was attached to the bulb with electricians tape.
Old Sep 26, 2016 | 10:46 PM
spdcat72's Avatar
spdcat72
All your bulbs appear to be in place in the cluster. Untwist the center one and see if the bulb is bad. I don't know why you would have a loose bulb and socket taped to a wire. That socket is meant to be twisted into the cluster. Sometimes those contacts can get dirty, and the light doesn't work. You can clean them with a pencil eraser.
Old Sep 27, 2016 | 04:24 AM
GreenMtnMan
Thanks. The bulb was bad and I did replace it. I was able to connect the wire to the bulb and the dash is now back in.
DaMonsterMonster
Nov 29, 2015 08:23 PM
riggz
May 13, 2009 11:18 PM
houghda
Jul 3, 2007 07:04 AM
ddwood55
Feb 2, 2006 04:19 PM
nhawki00
Feb 15, 2005 07:08 PM
